Hypergear what do you think the issue is with your latest 264rwkw turbo? The response is amazing and 260kw is a very good power output but it seems to have a huge hole in the midrange torque, is that the tune? what is up with that, is it because of the boost creep that it seems to get better?
So is an SS2 better than G3 with FNT??? or Billet wheels of the G3 Alfa version???
Prices?? and which is the best response?? I will be happy to get best response and reach 400RWHP..
Both SS2 and G3 are tested on the same platform and the SS2 performed better and it is truly more responsive to drive on road.
The original design goal is some thing has excellent driving ability while still have the max power out put as the G3. It’s also the fist turbo with FNT integration. That worked really well. Apart from focusing on its response and peak power, notice its torque, of how its wide and spread, that is the most important factor in creating excellent driving ability. It did cost more that is due to 4 extra machine hours.
I believe The ATR43SS-2 is the ultimate choice for responsive 400rwhp with the best driving ability.
On the other hand Alfa versions took over a year and thousands of dollars to get all facts right, It is a mascot of advanced engineering. How ever I never indented to sale it. Reason been is it failed to prove much differences in response to traditional bush bearing. The opposing energy slowing down shaft speed is surge pressure. Effect from rolling object is minimum. Plus the cost and time involved making it for us is impossible to market.
I believe the rear housing is too small or the comp wheel is too big, its showing its too hot. How ever the response and how it takes off is amazing, I would like to keep the current turbine setup and trim down the comp wheel size to make it work. I'm also in the process of building a slightly larger turbine housing to suit its current CHRA. That should work out pretty well too.
The SS1 also made 264rwkw and did not have a torque hole in the mid range.
I think the SS1 and SS2 are both fantastic turbos and cover the super responsive 250-260rwkw (SS1) and the 280-300rwkw with good response (SS2) markets.
I think you should focus on doing batches of these to bring the price down and get them out there.
Did the SS1 have the same response though?
I reckon the SS1 had better response in terms of torque and power but the boost response is 1-200rpm better of with this new turbo. The SS1 does not have the midrange hole in torque either.
See my results:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=336318
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=336319
Bear in mind my top end is lower then it should be due to a restriction I am currently diagnosing.
this! the ss-2 looks very promising
Ive got a 17psi actuator ready to go back on to the SS2, unless I can find a 15psi one somewhere. Once its all ready, I shall post up the results of the car with more boost.
This current actuator is SHIT HOUSE lol. If anyone is buying a turbo off Tao, GET THE 17 PSI ACTUATOR!!!!!!!! This lower PSI one can't even hold 10psi. The only time I get more than 10psi is if I get.... I don't know, it just happens when it wants to. It always finds a way to taper back down too, it just can't hold. None the less, even on 9psi, Ill be snaking on the road in 2nd off a perfect launch on cool nights.
The SS2 cost me I think $1340 or something. You might think its expensive but seriously, a Garrett alternative(3071 or 76) will cost you about $1700+ Then you need to buy a bunch of other shit to make it fit and get a new dump. Hypergear turbos, bolt on, tune, injectors, intake and away you go.
Ill list my costs on the performance aspects related to the turbo:
Turbo ATR43SS-2: $1340
Injectors Nismo 740cc: $650
Power FC(R33 Rb25DET s2): $1100
GTR Fuel pump: $80
Yellow jacket coils: $290 I think, bought off performance wise.
JJR bellmouth dump(I had one but it was cracked, repairs made more leaks) $190
Genuine Z32: $100
Clutch $380
Tune $800(plus other little jobs)
Intake pipe $30
Silicone stuff: $50 total
Venon 5" body 100cell Cat: $230
$4400.
Garrett counterpart will cost $5k+ with the parts I used above.
Car came with the basics, FMIC, exhaust, boost controller.
You wont regret a hypergear turbo.
Edited by SargeRX8
See my results:
er.. Actually your run was done on a 12 sec ramp making a fair comparison with that stock turbo's reading on the same ramp timing.
Mine is based on 9sec ramp. Compare to my original SS1 reading on the same ramp timing the prototype is about 500RPMs more advanced in response as well as torque,making it more responsive then a factory turbo. Come pass and test drive it when you free, totally unique driving experience.
Also it’s interesting that no one have ever ordered an ATR43G1. That is a 2530 equivalent turbo designed to max with stock injectors and AFM. Since its going to take about a week on bits and pieces for the prototype, I'll be building one for my self for a power run, should do 230rwkws with stockish response.
The SS2 cost me I think $1340 or something. You might think its expensive but seriously, a Garrett alternative(3071 or 76) will cost you about $1700+ Then you need to buy a bunch of other shit to make it fit and get a new dump. Hypergear turbos, bolt on, tune, injectors, intake and away you go.turbo
:O. I paid $1450 for a SS-1. I was told $1850 for a SS-2, that's why I went with the SS-1
SargeRX8 bought the demo SS-2 that was used on Tao's car. Tao will sell normally sell the demo turbos he uses for a cheaper price. He would have given you the brand new prices for a new turbo to be built.
Both Hypergear turbos I have used have been ex demo turbos.
Really keen to see some more SS-2 results on other cars.
Hey Sarge thanks a lot buddy for taking me for a spin in your ride, I appreciate that; your ss2 does make you feel the 'punch-in-the-seat' feeling that I'm after, but I expected it to be much more neck-jarring and brutal which is what I want.. :thumbsup:
Maybe that was because it is limited to 11psi with your current actuator as you said and also because we didn't go above 5000rpms?? Anyways I'm sure it will feel completely different with 18psi.. Thats gona be awesome mate..
Apologies Tao I missed the ramp time differences.
Having a closer look at this latest turbo, the torque curve could actually be very practical on the street. Instead of the usual hit of peak torque in mid rpm and then tapering off, this turbo makes a solid 400Nm of torque through the midrange and then steps it up again in the higher rpm. This would give a great feel of holding the rush, not to mention giving the tyres some hope of getting traction in the mid rpm (in lower gears)!
+1 for the ATR43G1, ~230rwkw without replacing injectors or AFM is prob the best bang for buck street setup on an RB25. I came from larger engines where response wasnt an issue and fell for the peak power game initially.
Its weird lol, I feel I can go faster if I get into the next gear by 5000 - 6000rpm. I red lined first the other day and you can really feel first gear is not enough to push this turbo once its above 6500rpm so I find it more effective to ram it into 2nd gear at 6krpm and keep the continuous "pull" feeling.
And to note, yes the turbo I bought was the test dummy. Never had issues with it. Shall be organising my tune up with DVS JEZ after my brakes are ready to roll and we shall see how we go on 17psi!
Have to take me for a before and after spin sarge.
Dont worry, Ron is a hard man to please. He like lots of revs. When tuning his car he keeps asking can we make the limiter Higher lol. What a champ.
I have another customer wanting a new turbo for his street gtst. I recommended a hypergear turbo, just got to work out which turbo.
Max 280 ish kw on high boost.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
