Nothing wrong with the GTR, it belongs to a member on this forum.
32 GTR had hks hard pipe kit, 100mil jap cooler, dump back HKS system, fuel pump, mines ecu, and from memory 268atw.
My E4 had an axle back exhaust and pushed 188atw with a failing fuel pump. As stated in this state it was 0-100 in under 5s and 0-200 in 13s. The evo would match the GTR at 70kph in 1st gear, then top out 2nd just over 90 when the GTR would catch it as the GTR would hang onto 2nd until close to 120. By that time I was running out of torque in high end 3rd gear and the GTR would walk away from 140+.
GTR stock weight is like 1550? My E4 hit the weighbridge at 1300.
Evo 9s are 1450, having driven one with an Evo green at a failing 240kw, I can say it is significantly faster than the said GTR even in its current spec of over 300atw using HKS 2510s. Owner has driven the E9 and confirmed the same. That E9 also had no spool problems and would easily overpower what I had prior (all with the capability of 300atw on E85 from the green turbo - td06sl2 20g).
To me that is a lot different to the way I read your first statement. This makes a lot more sense.
So you are saying the Evo4 was EVEN with the GTR in 1st gear, then the Evo4 got ahead for a short time when the GTR caught back up and passed it from then on.
Even a small difference in weight can make a big difference in acceleration there is no denying that. I used to have a turbocharged commodore weighing in at only 1300kg and even with a moderate power figure of 225rwkw it was even with many 300rwkw cammed LS1's that would have weighed an extra 200kgs or more.
Evo X does 0-200km/hr in 23sec, a Evo VI does it in 21sec, but a Evo IV with a cat back can do it in 13sec?!?
LOL
EVOS are not that light either, I know that the Evo 7 and up are more than 1400kg, which is equal to or more than a R33/34 GTS-t or GT-T
My searching says Evo 7 curb weight is 1,320–1,400 kg.
The difference in 0-100 between an Evo and a GTST or GTT would be traction on launch.
The above example is a GTR versus an Evo, there is a decent weight difference between those.
LOL
Everything didn't line up. If his car did that 200 speed, the gtr he spoke of is clearly faster if it walks away after 140km/h. If that is the case that gtr has a 0 to 200 almost as fast as veyron... But yeah back on topic.
Tao has there been any progress on the electric spoiling system? I've been thinking about it and this thing is going to affect the air flow meter setup. Maybe you will need two afm's. Or run a map sensor or create a ugly pipe with a u pipe coming out which holds the fan system in place.
Any one's got a dyno sheet of a evo including torque curve? If there's a turbo that has similar or better downlow torque then a evo then there might be a chance of beating it.
Any way, ATR43G1 is in the test car now. Super responsive. Should give it a new name: DDT. Standing for Dose dynamic turbochargers (that came from Trent :laugh: ). instant boost, makes lots of sucking, splatering and dosing sound, kept the BOV very busy. expecting 230rwkws with stock or better response. will post result soon.
video footage or it didn't happen!!!
video footage or is didn't happen!!!
I have a gcg turbo that basically does this, highflowed BB rb20 turbo, it is very believable. 230kw isn't a huge torque increase over the stock turbo, they will make 200rwkw if you really lean on them.
Evo's Australia forums now.
EAU
Evo's are lighter. If we are gonna talk shit on skylines we should be saying silvia's are faster.... Which they are :rofl:
covering my ears now, lalalalalallaalal dont hear anything, mm skyline lalalalla
  • Haha 1
lol, wasn't saying it isn't believable. Just wanta hear it.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
