What's this talk about not doing z32 with your Nistune?
I have a Nistune with no Z32 presently and was about to get one.....
You are starting to worry me...
Regards,
Darren
I always get data corruption issues on the test car, and with the new illustration car it does all sort of random strange things and knock map is not responding to the tune. The test car goes onto the dyno every week so the data in it gets changed quite so often, I'm not sure if that causes the issue. I believe the boards or what ever the ecu its originally made for is ok. The Z32 ECU and nistune chip on R33GTST just didn't work probably on my cars. Which it's also the reason trent stopped doing those.
So are you saying that Trent won't tune my car now that I have Nistune & an r33 on a z32 ecu?
Nooooooo.....
Darren
He did say he will never do another one. Do makes sense after all those stuffing around and no results. Talk to him nicely and see what he says. :rolleyes:
Sorry, whats this prototyoe pu highflow?? The 230kw one, or?
The 230kw one is referred to as the ATR43G1.
The other one is the SS1 PU prototype, which has also been referred to as the SS1.5. I prefer the SS1.5 as its easier to say and type :)
Correct me if I am wrong Tao
How do you know for sure its data corruption? Did you read back the maps and they were all spiky or did the ECU stop running? These are the indicators that something is corrupt, otherwise there is a different issue. I have to have a chat to Trent about this one
Shouldnt cause the issue. If unsure read back the maps which were originally in it and compare what was saved on your laptop after burning the tune
The main problem with using a Z32 ECU on an RB25DET is the knock sensors. Z32 ECUs use the doughnut SR20 style knock sensors and RB25DET use the hose type knock sensors. I suspect there is more sensitivity and your ECU is jumping to knock maps
We normally recommend disabling knock feedback during tuning for this reason. Also Nistune software will now indicate which maps it is running from at any time. Boards dont lose their tune once a burn is performed as its stored to EEPROM.
Just a follow up. Found out that Pete did the install and was supplied with a 16 bit Z32 ECU
We officially only support (and have tested base maps) for the 8 bit models for RB25. Part numbers listed in our documents for 8 bit models should assist with finding correct units
We have not used 16 bit models so haven't got experience with these but from what Trent indicated there are issues with these ones as well as a glitch found with VE map RPM tracing (fixed in 0.10.9 software release)
spiky or did the ECU stop running.
Yes
Well I'm not a computer gig, I've emailed you all the issues I've experienced as a user, I guess trent will be happy to go into details when he's free.
I'm in the process of getting a LinkG4 will post up some feedbacks once they are installed and tuned.
Interesting. Best thing to do then is read back the tune before pressing the 'burn' button. I'm in the process of putting checksumming over the ECU code to prevent 'burning' with bad checksums. However is taking some time to implement since the ECU doesnt like being paused for too long (ie calculating the checksum takes time)
Well, looking forward to see you guys making some thing work Properly with R33 GTSTs in the near future.
Update:
This is for a set of GTR turbos that we've asked to match port their housings and manifolds then do a high flow. We will be using ATR43G1 profiles in those with FNT turbine modifications, They are expected to make some where close to 350awkws at full capacity as a twin on 98 fuel.
Photos in comparison:
Those are photo of stock GTR manifolds:
Photo of the pair that we've ported:
Photo of factory turbine housings:
Turbine housings we've match ported:
Profiled turbine housing to suit larger turbine wheel:
Machined and enlarged wastegate port:
Hello there,
I use Nistune with the Z32 ECU and it as never failed me.
The 16-Bit-Z32-ECU is not recommended by Nistune (that's why I bought the 8-Bit back then)
(Though I know people using the 16-Bit-Version, and there were never any problems with data corruption)
Also I change my settings (tune) quite frequently, and this has never been an issue either.
The only problem I ever experienced was due to a bad Consult-To-USB-Cable which caused connection issues and rom-images
not being read correctly. I then ordered a Nistune-Cable, and it works very well.
Maybe your ECU is 'damaged', (lose socket, cold solder, or ...)
Edited by Torques
They didn't work properly on my cars, the ECUs on them are fine. I don't want to discuss those issues publically, and I believe Nistune is working towards solving those glitches in their systems.
But don't you have the 16 bit version, not the 8 bit one?
Hello there,
Lets get this straight it is not a nistune issue as much as an incompatibility between some Z32 ecu's and the R33 car itself, we have done about 20 or so (upto 400rwkw) and of those 20 about 6 give major headaches (r32 nistuned ecu worked so its not the cars), since i cannot differentiate the exact problems between ecu serials and r33 model series1, 2 or 2.5 i have stopped doing them, Stao's latest issues were the 16bit ecu.
Nistune is a great system and is generally our Number 1 recommendation for S13, S15 and R32 / R34's.... just not R33 with ecu conversions :P
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
