Have some very positive E85 results with the SS1!! Very happy, super responsive and 279rwkw up top!!
Cant wait to see some SS2 + E85 results too.
Thanks Trent from Status Tuning and Tao from Hypergear turbos!
FFS Stao is making himself THE ONLY option for skyline owners these days.
As always very very impressive.
Congrats lads!
How much to convert my 43g3 to the ss2? Damn buying my turbo early, Would have had all these lag problems if i waited for the ss2.
haha that doesnt make sense?
yours is laggy?
yours is laggy?
Wouldn't have sorry
yeah mine seams to be alittle off the pace with lag. Pretty sure its not the turbo causing it tho, with the ss2 i wouldnt have noticed it as much and could make more power
Stao it's in your best interest to answer me so Trozzle will be forced to upgrade aswell hahahaha
Actually all you need is the FNT turbine setup. that get rid of the flat spot down low, and the G3 accelerate very violently through out rev range with that mod on 20psi. Ask Pat to give you a rid. :laugh:
Whats the supporting mods for ss2?? (112 pages too long to read).. Im bout to upgrade turbo or should i go stao's high flow?! Whats the best options for a streeter/daily?? Something really responsive... My mods atm, the basic, full exhaust, fmic, ebc , fuel pump, nistune ...would i need the following; bigger injector, afm, and high flow turbo? Im after 260-270 rwkw...
Do you need the turbo sent to you to make the new housing? Would be a lot easier and less down time if you can do it would out the turbo? Pretty sure you've already installed an updated compressor wheel on mine
Edited by Crans
Use the SS1PU. thats is the perfect turbo for the job. and don't need much boost either
Thanks, just read few pages back and stop as i cant be fck, Is there any high flow turbo with very decent response without upgrading afm and injectors? Just wanted to do just high flow with stock injectors and afm.. What would be the Power output like?.. With the ss1pu, whats the poweroutput im going to end up with? At a higher boost?? U mentioned not much boost , 15 psi?
Edited by myRB25DETT
210-220kw is the absolute limit of stock injectors and afm, waste of time imo.
Thanks for that.. I guess that changes my priority now.. Whats the price for ss1pu guys? Ive got 2.5k laying around, whats the best option u would suggest?
remember with >220kw comes tyres, clutch, possibly diff, also trans if running an rb20 item, fuel pump, injectors, metal intake pipe, full 3" exhaust, intercooler, associated piping, ecu.
It basically costs the same for 230kw as it does for 330kw, including turbo if the car is 100% stock I would put aside $4k+ for it.
Below 230kw all you need is a turbo, half decent exhaust, at least an R34 side mount, nistune or remap. Probably be $1k + 500 + 250 + 5-800 so ~$2.5-3k to do it properly, almost certainly will get shitty having crap tyres and the clutch will die fairly soon as well though.
Edited by Rolls
So people say. Have you checked my dyno sheet in the RB25 turbo upgrade section?
If, in the near future, E85 is more readily available then my car with the SS2 will me running this new fuel. Until then, unfortunately, there aren't very many stations around offering the fuel.
Maybe the Government will offer some sort of rebate in getting cars converted to E85 fuel. That would be heaven lol. I would get my car to be flex fuel capable(some other guy here has done it, he can run what ever he wants, anytime).
Very nice output on the last dynos there Tao.
Ive noticed on both ignition dumps you have posted are more than the max ignition timing on my car. What is the cause of this? Was my tuner being too safe? Or do you think that there could be such a variation in cars that my car is set to run 42degrees max(I think, this is what PFC shows as my peak ignition when I punch to red line in any gear).
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
