Little update:
This is from the very first ATR43SS1PU (or referred as a small trimed ATR43ss2) which was fitted to a R33 with rebuilt auto:
In general Auto would lose around 20~25kws depending on how it was treated. So manual result would be around the 280rwkws mark.
Any way, SS3 with .83 dual gate rear is built. Will be tuned this weekend, hopefully getting the 350rwkws+. The GenEses charger is almost ready, will post some photos later in the week.
When you say the auto is rebuilt do you mean a standard rebuild or it has been modified, been thinking about going auto just unsure how much rwkw they hold standard and how much needs to be done to them to hold around 300rwkw as a manual
Think MV's rate them to 320rwkw with just a shiftkit and big trans cooler
cheers
darren
cheers
darren
Thanks for the info, been thinking about making mine auto for a while, if thats all it needs then i may just do it!
yes Auto spools faster and no boost lose during gear shift. They can sit there and do burn out all day.
yeah i drove a boosted auto r32 onetime and totally loved it..just floor it and hold on to the steering wheel while you drive down the road sideways :D
much better and faster for street and drag racing than manual...
I have one for sale too :)
I wont be doing it for a few months but pm me details and i'll drop you a line when im ready to do it and see if you still have it.
Need ATR43G3 or G4 to work on the RB2530det. Not sure about SS3 in .83 but all other SS series are too small for that engine.
Heres my 30/25det with ATR4G3. Only revs to five grand as injectors ran out of flow and we were unable to get it to hold low boost to rev the thing out.
I will reupload once its tuned with new injectors to find out what it can really do.
I shit my pants on 19psi.
You do get used to it though, very quickly :( Already considering upgrading again. But the amount of money I would need to spend just to get 40-50 more hp, can't justify it at the moment. Maybe when I can afford to forge then I'll go all out.
You can get up to about 300rwkws safely on 98 fuel with stock engine. Ask Stao to upgrade it to a G3 with .82 rear housing, He's done it to a mate for $200. Very big difference in power delivery.
Edited by GeorgesR34
Which turbo do you have? I've got the ss2 and the feeling everytime gets me pumped. Do you run e85? Forging the motor won't give more power, only forge if it pops otherwise I'll be buying an rb30 block :)
Yes, I'm currently making about 260rwkw. Thing is with sending off my turbo for Stao to modify, I live in Perth... So that's a huge down time for my daily confused.gif
I've got the G2, .64 housing. It's still just as quick, it still scares the pants off any mates that get in my car. It's just that I'm used to it now, 350rwhp got old quicker than I expected :(
No E85 in Perth, not at the pump anyway. I know forging won't give more power haha, I meant that when I can afford it I might forge and go for 500+.
    • Hi All,    I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off.  Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98.    Turbo is one of the first that was released but only done ~3k kms.    Asking $2800 happy to negotiate. Only selling to upgrade.   Located Gladstone QLD happy to ship.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is 2050 rpm, going to WOT sees the MAP go +ve very quickly and it has >5 psi by the time it hits 90 km/h. That's still <2.5k rpm, so I think it's actually doing really well. (I edited this from a previous version where I stated 80km/h was <2000, but that was a false memory. If I am rolling at ~1700 in 5th and floor it, it will start making boost before it goes over 2k - which is a separate "experiment" leading to the same conclusion. Which is that the boost threshold is actually quite low. It's not fast there, obviously, but it certainly makes progress towards going fast, which is not what it's been like for a long while!!) Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
