That is for sleeve bearing. BB turbos are roughly 10% better in response. They can be fitted with GT3071 or 76 CHRA. will cost roughly $500 additional.
Below is the commercial version of ATR43. This is now available. The turbo comes in 4x different profiles:
ATR43G1: 450HP in . 58 / .63 rear
ATR43G2: 480HP in . 58 / .63 rear
ATR43G3: 520HP in .63 Rear
ATR43G4: 600HP in .84 rear
It is designed to bolton to your stock manifold, dump, water, and oil drain. Braided oil feeding line is required and priced at $80 with turbo. All turbos can be built with a Garrett GT Ball bearing CHRA depends on consumer's budget. To fit them to factory intake and intercooler pipes you will also need 2x silicon pipes one in 90 degrees 2inch and the other in 3inch straight.
ATR43's .58 and .63 Turbine housing is interchangeable with All ATR28Gx High flows that we've sold. Will gain instant power increasement specially to the ATR28G2 based R32 / R33 xIU high flows, Should have No issues archive upto 270rwkws with supporting moods.
just a question i got a tr43i off you a few months ago for a r33 that I wanted to run 300kw with is the one I have one of these or are these the new ones or is that why these are calld atr43g because there different?
The ATR43's shaft is liter, It has less fins and bigger gaps between fins. So compare to TR43i it would pickup better response and make more power with better torque. If you compare dynosheets with ATR43G3 and TR43i you probably find some thing looks like this:
I also engineered one with sized and weight reduced shaft using shorter bearings for even better response. But its obviously a stronger turbo with bigger shaft and bearings. So till that gets tested out we will stick to this recipe.
This is the first ATR43 G3's tuning result based on a forged CA18det with 270 / 11mm cams (Still hunting for a Cheap R33 testing car.)
car made:
299rwkws / 401.3HP Wheels @ 19psi
344rwkws / 461.5HP Wheels @ 25psi
Dynoed and tuned on 3rd gear.
Simple question,
i want 270kw at the wheels (max) S2 R33 GTS-t. What turbo would do this, how much would it be, and would a high flow do this?
Cheers
Chris You need to slot the actuator bracket and pre-load it about 3mms and you should get about 9psi with no boost controller. You will get a different boost response once you done that. We do that to all the actuator attached RB turbos sent in for high flowing. also if you run a bleed valve with higher boost settings it would also affect alittle bit on response.
Feel like making a how too? How does this mod go with a stock turbo?
Yes but that was in stock R33's turbine housing. Now they are running in a .63 T3x rear housing, The spec of it is very similar to a GT3071. So it should make around 260rwkws at 18psi of boost on 98 fuel
Which turbo is that? how would it go on an RB20?
To get 270rwkws we can make it close to it with a R34's OP6 rear housing. The cost for doing that is $880 with oil line.
Or we can supply a .63 turbine housing using ATR43G2 CHRA with your stock comp housing for $1230 including braided oil feeding line and 14psi actuator. This is also suitable for all the RB20det engines.
Also youtube video for the 344rwkws CA18det dyno run today:
Ive just read through the post and im more confused.
I have a R34 Gt-t i want around 250rwkw (a little more if possible 270rwkw?) response is the main thing im after as the car will be used for street and club level sprints etc.
I want it to mount up to the stock everything for reliabilty etc and also for it to look stock, what would be best suited to my needs? And how much?
Thanks,
Thanks,
Did you need read the last and 3rd last post before yours, seems to be your answer.
Simple question,
Cheers
Edited by W0rp3D
thats impressive results and thats on a ca18 would be interesting on a rb 25 at 18psi make some serious power, and on the youtube it said its the g4 profile but youve posted here its the g3 which is correct?
hello Peoples, i finally got my R34 retuned with my 660CC injectors and retensioned the wastegate. it made ever so slightly more power. but for the sake of 10HP i would have left the stock injectors in there. we tried ramping up the boost more but made absolutely no difference. ie 14 psi made 290hp and 300 on 16. i would put money on it that you simply cant flow more through a r34 op6 housing. or there is a big bottle neck some were.
the car was tuned with a full 3' ex with no cat and only a cannon muffler. z32 AFM, power FC on a dyno dynamics dyno. all tunes and runs were done on the same dyno.
don't get me wrong i'm not unhappy with the setup, it drives great and sounds sweet. I just thought it would have gone a bit further with out needing to change the ex housing. which i may do once I'm bored with it, aslong as i don't build a Rb30 as a project.
CHRIS_S_R34__DYNO2.pdf
CHRIS_S_R34__DYNO3.pdf
regards
Chris
Hard to say. So far I've seen 256rwkws with OP6 Rear housing. and 235rwkws with R33's 2IU housing. We also have another way to high flow which can increase about 20HP more but trade away fair bit of response.
Also one more thing I would like to address its funny that not all Turbos that came off a R34 had a OP6 rear housing on it, wither its been changed or came out OEM I don't know. You might want to check and make sure there is a OP6 stamp.
This is a reading out of a OP6 housinged R34
Any way, we also have .63 Bolton housing available at this stage. If interested to upgrade please let me know.
how would the .63 housing hurt response, say compared to the OP6?
it looks like the OP6 overtakes the stocker at about 3500rpm, would the .63 be closer to 4000?
With .63 will be looking at 20psi at around 4300RPM. But it will be able to flow lot more power. But either way OP6 rear housing is good enough to flow upto 260rwkws with 98 fuel and a decent tune.
Hey Stao,
yeah when i pulled mine off it deffinitly had op6 stamped on it and it still does :D (i just checked out of curiosity). It could be also the difference between dyno dynamics and dyno pack. do you happen to have a dyno sheet for the above car? ie my car pulled 253Hp at the wheels on 14psi (stock) then pulled 290HP on 14psi with the highflow. therefore same pressure but 50hp worth of air. so if the other car started at 210kw and then went onto make 250kw it would all be about the same gains. if that makes sense?
Could you please PM me the price for the bigger housing.
ahhhhh too many variables lol, at the end of the day its still damn good fun tho. sorry about my waffling out loud.
Regards
Chris
Edited by urtwhistle
I really don't know why it didn't make power on yours. The CHRA that went into it all OP6 housings are idential. Also most of R33 2IU's people's high flow have made around 235rwkws mark. Status Hub dyno reads within 1 KWs to Mainland roller dynos. it can't be 50KWs off unless the dyno you went on actually read low.
also Are you using BP or Mobile 98 fuel? Was your rubber intake pipe sucked shut on boost? Or clutch slip?
The .63 rear housing that bolton to your stock manifold and dump cost $500 to make. I will need you to send the turbo back for its housing profile.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
