This is the new SS2 prototype trail using the external gate turbine housing. It actually made about 300rpms better in response. how ever didn't help when the car caught in fire. lol. One of the rubber hose expanded under pressure and torched on the exhaust manifold. Well, made 293rwkws when fire broke out. lol. Will do a bit more trailing in later stages.
looks very nice @ only 20psi too
Impressive, how is the heat with this one, could you drive it for 10 minutes in the hills flogging it non stop at ~4k on full boost without it starting to detonate or lose power?
Also what is with the torque dip when it hits full boost, lots of your dyno graphs seem to have this, is there any reason?
Edited by Rolls
This one is pretty alright. Wasn't getting very hot. Turbo was ok. We didn't get too many runs as the rubber hose caught on fire. Floged it this morning with all the rubber hoses replaced and its so much fun with external gate.
not getting hot...but vacuum lines caught fire?
this thread can bring the lulz at times
If a rubber vacuum line touched a stock dump running stock boost it would probably catch fire.
It's probably not very important to some, but for what it's worth I flogged my car for three days straight at Powercruise this weekend and it loved it. Not a single issue at all, and the performance of the G2 was great. Didn't get too hot, just kept going all weekend.
Stao, I'll be watching this thread closely. Keen on an externally gated turbo capable of 300rwkw that doesn't lose too much response without having to change too much of the stock setup. Going to look into water/meth injection to keep things cool. The turbo you're working on at the moment sounds like it could be the perfect fit.
awesome! what turbo is he running?
That was a old TR44 turbo. They are the ancestors for the current ATR43G3. I still have few housings and wheels for those used as door stoppers at moment. Can put them together for $450 with 12 month warranty for any one whom wants one. Externally gated only.
Also some winton drifting footage from Abe's car. It made 290rwkws using the old ATR43G3 none FNT version.
Its currently making 347rwkws with the FNT update on E85. Should be seeing him hitting the track soon.
Edit / add:
The youtube quality sucks, you can down low the raw footages from links below:
Door mounted camera
http://www.digi-hardware.com/photos/abphotos/sidecam.wmv
Roof mounted camera
http://www.digi-hardware.com/photos/abphotos/topcam.wmv
That is enough evidence for me.
Agreed on the too many turbos thing zebra.
Something like this would be fantastic
turbo name, specs @ x psi, peak kw, peak nm, peak torque -25% from x-y rpm (eg 3500-6500rpm), cost, internal/external gate/housing type
Edited by Rolls
Stao - Can we get a run down of all the products you currently offer....Ive tried looking back through this thread but info is all over the place
Pretty much what ever you see on our website. Here is a mixed of older, current and under development products. Once a better product is developed, the older version of it is automatically discontinued and replaced. Just like the ATR43G3s built in 2008 is a completely different turbo to what it is today.
The Youtube video quality is so bad compare to my original footage, I’m seeing many familiar cars. Yours might be in the footage. I will post an http link once they are uploaded.
Is it possible to compile something like what I said stao? I saw that you put quite a bit of effort into overlaying all your graphs in the past, would most likely be less work to do this. :)
Could we get some footage of you flattening the throttle at 2k in 3rd gear until like 6k or something? I'f you could film the tacho that would be fantastic, love to get an idea of the transient response on the road. :)
Ill get this footage tomorrow. Ill try to push it as far as I can. Did anyone notice the XR6 lol.Tailgated me a fair way waiting for me to run him.
Edited by SargeRX8
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
