Also remember that while there is even pressure on both sides while the system is under boost. When you throttle off and the throttle body closes, one side has (in this example) 30psi and the other side has vacuum. This is where the BOV's function comes into it, but having a larger pressure differential along with age/condition (As above) is going to strain the diaphram more. I know they will handle 20psi all day every day no problems (if there in alright condition) but if you Jam 50psi through your system it means that there is about a 50psi (minus spring tension) pressure differential at some stage which means there is a little less then 50psi jamming the diaphram into the body, or whatever is holding it in position
I'm not saying it WILL fail, I'm just saying the more boost you run through it the more your playing with fire.
Also some winton drifting footage from Abe's car. It made 290rwkws using the old ATR43G3 none FNT version.
Its currently making 347rwkws with the FNT update on E85. Should be seeing him hitting the track soon.
Is abe running a 0.82 rear? Does he have cams? Great result! Car looks tops in the photos too
Yes a billet electric supercharger that makes 7~10psi boost with a 1200HP Compressor. Need to work out in car wiring and its pretty much ready for testing.
Given some variable speed control I rekon you could easily make something NUTS out of that.
Goodluck Stao, it will be interesting to watch you pioneer the concept in public to say the least!
I've had the test car tuned current FNT ATR43G3's this evening. Basically straps on, internally gated on 98 fuel. The most it made was 330rwkws on 23psi, and 320rwkws on 20psi. The runs were performed with a high pressure actuator internally gated. The 20psi run is without boost controller.
The No.s were very consistant. This turbo doesn't get hot at all. Compare to the older G3 there is small difference on paper but huge in driving ability.
That looks like it could be my new turbo :D
You have a PM Stao.
The ss2 made the same power at the same boost but 400rpm earlier... But maybe that turbo, being larger maybe not so much affected by heat, but even after long drives and runs through stanwell tops, I wasn't detonating or losing power
Yes, but I'm not just looking at the peak power. Compare the torque between the two. This turbo makes 530nm at 4500rpm, compared to the SS2 which only made 493 at 5300rpm. Then there is the area beneath the curve. This turbo is making slightly (not very much admittedly, but it's still there) more power at each rpm increment than the SS2. The SS2 only caught up just before redline. So they may make similar peak power, but this turbo looks like it would be better on the street. I am also concerned about the heat, as my motor is stock. It does get tracked occasionally, so I really need to be able to keep temperatures down.
Also not sure what is going on with the boost plot of the SS2, it really only makes it's peak boost at 5500rpm, so it's obviously getting a lot of boost creep. Not reading too much into that, it's just something that I noticed.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
