Well the SS2 is more responsive, while the G3 pulled a bit harder up top.
I've got few more drawings for the G2 which I will have it made and tested soon. I'm hopping the new G2 can produce around 280rwkws using less boost based on similar or better response of what it currently has.
Some trailing with GenEses prototype was conducted this afternoon. That is the biggest hair dryer I've ever had. It drained my spare battery (my old car battery) in about 3 mints. I shot the last 5 secs before the battery died out. Will do further evaluations soon.
http://www.youtube.com/watch?v=2_k0aYiczFM
I've had the test car tuned current FNT ATR43G3's this evening. Basically straps on, internally gated on 98 fuel. The most it made was 330rwkws on 23psi, and 320rwkws on 20psi. The runs were performed with a high pressure actuator internally gated. The 20psi run is without boost controller.
The No.s were very consistant. This turbo doesn't get hot at all. Compare to the older G3 there is small difference on paper but huge in driving ability.
Also compare to the E85 Abe result based from the same turbo. It looks like E85 have made it producing more power and better response.
Stao I would love to see what E85 does to your current setup :thumbsup: .
what rpm does the electric charger do?
Will all depend on how much load it is under, eg if you are blowing it into a 10L motor with no restriction, or a 1.5L with conservative cams, one is going to load it up much more than the other.
I am very interested to see how it goes.
Stao if this electric turbo charger works, is it feasible to adapt it to a turbo charger so you can pre spool it? Eg run a belt or gear drive to a custom bearing housing so it can be turned on and off at will? I'm not sure how you would clutch it so it doesn't pose a restriction when on boost and you want to disconnect it though.
Did some testing today. It drains lot of battery, and I'm using 0 Gauge cable that turned pretty hot. taking it to a proper electrican to have the circuit loom made before pluging in to my car.
Some footages from today:
http://www.youtube.com/watch?v=MAqVTXEqBe0
Should be good for 5-10 second squirts then let it recharge. How will you bypass the turbine blades when it isn't in use as surely it will act as quite a large restriction, or will they free spin quite easily?
NO it doesn't spin when its not activated. So I've used low velocity wheel with a huge compressor housing. shouldn't create intake restriction on a small NA engine.
I've been testing it all afternoon, The Optima battery has no issues. Still fires and run after like 50 short runs. Would be similar to a Nos device that activates in short time pulses. This thing has no lag.
roughly 2 weeks if I don't run in to any more troubles. I've got a improved G2 design that I want to test out first. If all goes well we should be able to get close to the SS1PU's power, torque and response while not the extra coins and time making it.
How have you estimated it will make similar airflow as the G2 does?
Have you hooked it up to a flow bench to calculate how much flow it can create? Just not sure how you came to that figure.
Works every time right? :turned:
Flow bench only tells what the compressor can flow, how ever it can't predict how the whole package can perform on a certain engine. I prefer to physically test it, and after testing that many combinations I get a pretty accurate prediction of how things would turn out.
A Skyline amp is ~65amp, correct?
If that thing pulls 100amps, would beefing the generator system up to say 150amps provide enough stink to run it constantly? Or at least for much longer times than say the odd squirt for 10 seconds or so?
My issue with this (even though a good idea in theory)
Is the current draw, whacking a 300amp load on top of running fuel pumps, ECUs dash/head lights etc is going to make the car simply shut down.
In my car I can hear the fuelpump change tone ever so slightly when the brake lights come on and go back to normal 1/2 sec later, that would be 5-6 amps max, If I tried to whack 300amps on in 1 go the whole car would stop.
The other issue (if the car keeps running) is the huge voltage drop will affect the ignition and injectors and throw the tune out.
Still keen to see if it works though.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
