Ok I've now fixed my air leak (loose hose clamp), changed exhaust and removed the boost control. Still getting 22psi dropping to 14psi by redline. Stao can you send me a stronger actuator to try.
Was that with the air box lid and filter off?
I couldn't suggest running without a filter. I had a 1mm gap between the gasket in my apexi filter and z32 and enough shit got in to damage the turbo fins. Silly idea. At least put a stocking over the box snuggly so at least you know some shit wont go in.
One run down the street should be fine surely? Just don't drive through gravel or anything like that. I'd be more worried about the sock getting eaten.
Edited by Rolls
So has anyone got their SS1PU fully tuned with dyno results yet?
I got mine in the mail yesterday, should be fitting it this week.
Yeah, 260rwkw on 19psi, stock internals. Dyno vid is on youtube :)
xxswitchfloxx
Mods are on there also. I might have a dyno pic lying around too ill post up in a sec
xxswitchfloxx
Thanks mate - dyno would be awesome, esp with the boost. Does it hold 19psi all the way or run more/less in the midrange/top end?
Whats it like to drive?
19psi at like 3500-3700+ rpm, then dies down to 17psi by redline.
Stao mentioned i use the screws that came with it to stop the boost dropping, some sort of airflow changing method. Not sure how it works, but seeing as its a pain in the arse to get the turbo off theres no way i have the time to take it off continuously to see how far each screw needs to be turned for the boost to stay level. Not to mention the time it takes for the turbo to cool down enough to touch..
Very fun to drive, not the best top end acceleration but that's not what i wanted. This is my daily driver, so i wanted low end power and that's what i got.
Spinning wheels in first and second and get sucked in the seat :)
Keep in mind, those results were after a lot of runs, so heat-soak set in. I reckon on a cold day + first try it would make over 260.
Has anyone been in a car with a atr43 g3 and atr43 ss1. I'm considering upgrading from the ss1 to the g3 and just wanted to know what people think of the difference.
Do you need to upgrade or do you need to work out your issue?
IIRC your already making the projected power for the SS1 though arent you? Being 240kwasps
It's just a possible solution to the boost drop, stao has suggested the upgrade or a bigger actuator. But I'm deffinately not happy with the power but i don't think that it is the turbo. My tune is all over the place.
Edited by lilcrash
Do u have a dyno graph lilcrash?
I have done a g3 on a 34 but maxed the stock injectors at 232kw 19psi 6000rpm
And dynafits ss1.5 259kw 19psi with weak clutch
I have had both on my car with exactly the same mods. They are completely opposite turbos. The ATR43G3 was over 1000rpm less responsive then the SS1, was a HUGE difference. I was able to make 280rwkw with the ATR43G3 and 245rwkw with the SS1. The SS1 is way better for the street, standard turbo like response. I now use E85 fuel and make 280rwkw with the awesome response.
On both turbos my boost would drop to 15.5psi no matter what I did, boost controller, wastegate studs etc. I found replacing my intercooler and fixing up the exhaust helped as now boost only drops to 17.5psi. So for me it was other restrictions in the setup that were holding back the boost up top.
If you wanted to go bigger I would stick with the SS range, either the SS1PU or the SS2. I thought the ATR43G3 was too laggy for a street rb25. The SS2 is around 3-500rpm more responsive then the ATR43G3.
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
