I have been thinking though. The stock turbo was set to 13/14psi but in cold weather had no trouble pushing over the boost limit though my intercooler and it's a much smaller turbo.
One thing to note on my current setup is my actuator gets it's boost feed from the cold side of the intercooler so technically the turbos wastgate should be shut tight when my boost starts to drop.
Rolls - that's why I'm here, to see what people have on their cars. I think I should actually use what ever stao has on his test car as it "should" give similar results.
Yes but your new turbo is now flowing much more at that given boost pressure.
You should hook the actuator to the nipple on the compressor, why on earth are you running it from the IC?
Re using the same IC as him that is a really good idea, at least you are removing another unknown that way.
Edited by Rolls
There isn't a nipple on the compressor. The fitting that used to go to the charcoal canister was the closest fitting I found.
FAIL!
This will be half your issue... Run it from the compressor cover or the cooler piping BEFORE the intercooler
that is weird that it doesn't have a nipple on the compressor housing, are you using one of HGs aftermarket housings? If so how does he set them up?
If anything though running the hose from anywhere else should cause boost spiking, not bleeding off.
Edited by Rolls
I think its best to send it back and swap for a FNT G3, I can give you my 330rwkws nistune map, load it in and see if that changes boost and power behavior, That turbo should also suit your driving style better.
Ok I'm sick of playing this game now. Now it only makes 16psi and nothing has changed
You're changing it's symptoms, that's a good thing. Just keep working through it.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
