The boost level seems to be affected by temperture. Just had few very hot days in Melbourne and the high pressure actuator seems to be holding 18psi instead of the 22psi when its cool.
Also shouldn't the engine run rough as with the tooth skipt on the cam gear?
I'll be looking at getting a hypergear hiflow done soon (as I'm only going to be chasing around ~230rwkw) and will have two turbos available:
a stock 45V1 VG30 ball bearing turbo, and a stock 45V4 on my 1996 series 2 RB25DET
Which one would be better suited for hiflowing with responsiveness being the priority?
Can Make around 260rwkws with the VG30 turbine housing. stock Rb25det housings are good for around the 240rwkws mark. Either of them would be good enough for the goal of 230rwkws.
Under that rubber pipe is just a white plastic hose that dumps condensation when A/C is on. The water comes in due to the car's acceleration momentum, get a rubber plug in that size then cut the center section out for that plastic hose. That would stop any water drain in to the cabinet.
Just had a look then and my a/c rubber pipe doesnt have any white plastic hose underneath? The whole top half of the black rubber a/c hose is burnt on mine. Couldnt work out where it comes into the cabin or how to put a rubber plug anywhere??
There is a white coloured hard rubber pipe under that rubber, water comes out of there when the A/C is on. Just make a plug from a bit of materials in Clark rubber for the frame and cut a hole in the center for that plastic pipe. That would stop any water drop draining into the cabinet. or just connect what ever bit of hose on to that pipe.
Is your dump a JJR item as well?
Mine is just flexi rubber hose, I can bend it and because the whole front is melted I can see inside and theres nothing white inside.
I cant workout where it joins inside the cabin.
Yes its a JJR dump pipe.
Seems to be an common issue using HG turbo on JJR front pipes. Pull that rubber piece off and there is a hard plastic pipe in it. Water comes out of there.
Edited by GeorgesR34
am interested in this as i will be going HG in a couple months. since my engine bay is stripped out ill try to get detailed photos up tonight so we can all have a good look :thumbsup:
That would be awesome if you can take some photos so we can all have a good look!! Hard to see with everything in the way.
Hey Sarge hows ur new intake pipe and lean popping issue? I just ordered me a set of YJ coilpacks, did u have issues with yours?pinch.gif
Lean popping wasn't an issue, I don't think. There was nothing there causing the lean pop and after fitting the AFR gauge it was showing that it was running around 13's which alot of have said will cause lean pop. I got rid of it by richening up the idle mix. Some people run 17.1 afr on idle and they put up with lean pop, I tried it and f**king lol no way in hell. It sounds like shit and the car feels like a rough v8 on idle. New intake pipe should be good. No more rubber or tight corner, a nice 90 degree 3" all the way through. It seems to have fixed my coming off boost stalling issue!
I had issues with them, I got a refund and got brand new OEM coils.
I found when I angled the bov return and pcv valve return towards the turbo inlet and away from the afm it solved my off boost stalling issue.
;) Its not so much the breather line as that is just under vacuum, no air gets pushed through it, shit is sucked through it, its more the BOV return which if when it releases the boost in the system, it hits the AFM, it goes into a fueling mode, adds fuel and stalls.
I think you hit the nail on the head with this statement. I remember u had a lean popping issue when u changed ur intake earlier, and maybe this was the reason above. Where'd u get those two little breather pipes with the rolled edges thats welded onto ur intake?
When I made my intake pipe, it was near impossible to run the standard BOV return so I chopped off the end and rather than throwing it out, I used it as the bung to weld on. If you are anal about it and want the edges rolled like that, buy another one that someone is selling (they are cheap) and cut as long or short as you need to line up with your bov return. I also ran a catch can so the hard return line for the oil side wasn't necessary.
so looks like if the hose gets blocked it will flood the car. also if its squashed or pulled in the wrong direction it will also get into the car. i might try cut it a little shorter and slip a bit of hose over the white tube and have it running down the inside of the black hose.
i cant see how the hose melting makes the water get into the car unless its blocking the hose when it melts
Edited by t_revz
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
