Is this one a straight bolt on with factory comp cover and factory dump pipe?
Any chance of getting a graph that shows power+boost with an rpm scale?
To Get about 260~270rwkws we can machine your stock comp and OP6 turbine housing then use ATR28G3 CHRA with a ATR28G3 with a cropped turbine and 14psi actuator. That should be ok for up to 270rwkws assume your Auto can hold it.
To do that it will cost $800 + $150 Turbine wheel modifications and actuator + $80 braided oil ine + GST = $1133
we will need roughly 5 days on it.
With ATR43 .63 turbine you can get similar power without having to crop the turbine wheel which get you lot better response. To high flow with the cost of turbine housing is $1230 + GST = $1353 including oil feeding line
Here's one with RPM in it (transferred the scale from Dr.drift's dynosheet):
Unfortunately the Boost analyzer at Phase auto got run over by a customer's car and currently broken. I have a sheet from Trent last week.:
cool thanks stao,
So the first option would require me sending you me entire turbo?
2nd option is that made completely of your housings? or do i need to send you a turbo of some sort?
ideally i'd like to not have to take my turbo off as i need the car to get to work. and then i can sell it later to offset the costs.
Can easily get my hands on a stuffed 33 turbo if that makes things easier?
you have so many different options im getting confused which one uses which housings etc haha
if there is not an option i'll just have to do it i guess. just sussing out my options.
seems to be turning over top end a bit early for a rb25?!?
With the top end. I'm suspecting that is due to the exhaust housing maxing out, or might be some thing to do with the actual engine. floor 4th gear the RPM fluctuated its way from 5500 RPM to 7000RPM. But it does not fluctuate on neutral. I’m not sure if all my boost were turned into blow by.
For 272rwkws I think this is the most responsive result I've seen. even compare to most of the high flow results. Looking pretty good, keen to see what it does on a healthier RB25 engine.
stao, any chance of getting the car to have a power run on another dyno eg. dr drifts or status???
would be good to see a full rpm pull up to 7000-7500 and also the torque/boost figures... the graph you posted seems a little wierd and says it makes 809nm which seems to be way too high
Hi Stao
would like to thank you for your excellent product and customer service mate. Little bit of background info: I bought a Hypergear ATR28G3 off Stao as an upgrade on my R33 RB25DET S1. Only looking to achieve approximately 250-270rwkw. The turbo is on the car now and on 14psi with power fc, 740cc Nismo injectors, splitfire coilpacks, greddy fmic, AM Performance exhaust, Bosch 040 fuel pump its making 246.6rwkw with a leaking exhaust. Ran out of time as i needed the car hence why the car was tuned with a leaking exhaust.
According to the tuner there is potential to get around 260-270rwkw with this turbo once the leak in the exhaust is fixed and the boost is raised. The turbo was a straight bolt on.
Highly recommended!
Thanks
Krishy
Thanks for the support.
I Probably go to status with the new R33 S2 in few weeks. I won't be taking my current R33's result very seriously, this engine's knocking with poor compression. Also this Fluctuating RPM probably indicated huge amount of blow by.
I have a problem with my turbo installation. I have included a picture of my old one and the new one so you can see the difference. It appears the compressor outlet on the high flowed one is rotated around too far and is hitting the exhaust manifold when I try to install it. In the picture I have a ruler across the face of the exhaust inlet on both turbos. On my old one there is a large gap above the compressor outlet, but on the high flowed one, the compressor outlet is holding the straight edge off the exhaust inlet. Can i simply loosen the bolts on the compressor housing and rotate it round to the correct position or will this screw something up internally?
Hey there guys, Nice nice, ive got basic mods like
full exhaust 3inch all the way with bashed out car
740cc highflowed injectors
power fc
z32 afm
pod filter
splitfire coil packs
walbro gss fuel pump
and a hypergear highflow with stock r33 housing atr28g2
greddy profec spec b II
and i got a tune from Trent @ status tunning doing 233.3 kws on 17.5 psi.
i wana reach 240-245 atleast... is this possible?
power fc
z32 afm
pod filter
from memory we cut tuning short on yours as it had boost issues (leaks or something) im sure there is more in it but have you fixed the boost issues?
Flargh:
You only need to lose up the 6 bolts under the comp housing. Then rotate it by very slight. then it should be fine.
Geraus to get 250rwkws you will need to run it on a OP6, or .63 rear housing. Or I can crop abit of the turbine wheel for better flow.
We also have .82 rear housings with the same bolt up pattern which I'm putting one on as we speak.
hmm, i re did my intercooler pipe and my turbo manifold 4 bolts. i made them tight. i'l bring it down soon just got a get some money hehehe . :happy: i'l book as well thanks.
Flargh:
Thanks mate, that's all i needed to know.
Hi mate. I'm chasing around 300rwhp or 200rwkw. Slightly not or less it don't matter. Don't want a lag monster and I don't think this power level really requires one. Looking at modified r33/34 turbos. Do you have anything off the shelf ?
Wish I could get a hks 2530. But funds won't permit
We can build you an identical spec sleeve bearing version of 2530 for about $1450 with oil line. Its ok for up to 230rwkws with super fast response. or we can sale you a high flowed R33 turbo for $1180 with oil line. should do similar sort of HP with slight less response.
g'day stao i'm looking at upgrading my stock turbo.
supporting mods are nismo 740cc's, fmic, fuel pump & ems stinger.
i'd like to take the rb25 to its safe limit, so around 330rwhp from what i read is reliable.
my question, is what would be the best for the street, i'm guessing a tr43 g2 with a .63 housing?
or would it be worthwhile going to a .82 housing ?
and aside from the oil line, thats completely bolt on yeh?
sorry about all the q's, i've been reading nonstop for a few hours and i'm a bit confused.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
