They won't help much with internal gates man. I held 20psi just fine with the previous Hypergear setup mind you.
You should probably get the same setup as me so I can see how you go with the VIPEC :D
when are you hoping to have your turbo in if you decide? ill see ur result, and opion bout this LAG buisness b4 you see mine as my car is goin in 20th of this month to get wired at c-red as this engine is in a s13 so prob looking at april b4 i run this turbo. i hope to see fairly good results
it looks that way. I am hoping my intercooler isnt too restrictive.
Realisticly, probably next month it should be ready for a tune.
yeh i have neo engine, whats tcs? i gather its traction control tho
Yeh traction control. Make sure they wire it up. They deleted mine and now it's causing me endless headaches.
im running a no name intercooler so i wouldnt be worried bout a trust or gredy unit unless its one of those ones a tad bigger then a stocker , HANALDO are u trolling or serious u whant them to wire it even if it is in a s13 not r34? he swore everything would work as it would be, as if i was driving in a r34 ,ovisiously without traction control
Edited by skyzthalimit
It depends on what ecu you're using mate. I'm using NIStune, and the lack of traction control is wreaking havoc with the stock computer, making it pull fuel unexpectedly and things like that. Gives me a very rough power curve and makes it very hard to tune.
They also didn't wire in my stock boost sensor, they replaced it with my EBC sensor and that's giving the same trouble.
I mentioned. before that Im also running a stagea ecu on my R34 with R34 maps and Nistune - No TCS, hasnt caused me any problems at all except that theres no traction control. Have u tried swapping a diff working ecu Hanaldo?
If i remember correctly its a trust greddy m-spec kit from an R32
That should be fine. If anything the G3 will be restricted by my cooling pro turnflow as the core is smaller.
Got some data from a customer's R34 yesterday running a FNT .82 G3 vs Jeff's std .82 PU high flow on 18psi. There is about 250rpms differences in response with lot better road drivability.
Yup can see the improvement there. Also the hit of boost is slightly smoother so would give the tyres a bit more chance of holding on with the FNT.
Interesting to see that he could only make similar ~280rwkw as well whereas on your car and others it has made 300rwkw+. Wonder what is/was holding them back.
Defiantly going to send my turbo back for the FNT upgrade, just gotta wait till I can afford a 44mm wastegate, may as well upgrade to external if im getting a new exhaust housing.
Where can i buy a good quality gate for less than the $600 i keep seeing the turbo smart items for sale for?
I got my comp-gate 40 for $330. 44mm will be a bit more expensive though, are you sure you need it? Mine holds boost perfectly and I'm only running 18psi, if you run the full 20-23psi that the turbo is capable of then I'm sure the 40mm wastegate would be more than sufficient.
Just keep an eye on eBay if you know how to spot fakes, there's plenty of genuine items on there thumbsup.gif
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
