Interesting to see that he could only make similar ~280rwkw as well whereas on your car and others it has made 300rwkw+. Wonder what is/was holding them back.
Note he was only running 18psi, I made 289rwkw@18psi on my hub dyno run, so quite similar. I believe Stao on his 320rwkw run was boosting to 23psi? In any case, I'd say you will need to run at least 20psi to crack the 300 mark on pump 98.
Edited by Hanaldo
Yup can see the improvement there. Also the hit of boost is slightly smoother so would give the tyres a bit more chance of holding on with the FNT.
E85 & more boost, gogo
Nope, Stao made 305rwkw with the exact same turbo I had and was only running 18psi also.
See how my boost is dropping to 15.5psi. No matter what I did to raise the boost it would drop back to 15.5psi. So no point in increasing it for it then to drop off up top.
More midrange punch
There is an adjustment on the back of the turbo, you can adjust the creep amount with an allen key. Stao can give you advice to doing this.
I think the outcome is that you will boost higher up top than down low, but thats not really an issue if you just turn the boost down to suit
Oh are you talking about the PU high flow? I was referring to the G3.
Got a graph of Stao's run? I can only find the one where he made 295@18psi with that turbo.
More midrange punch
Yeah true I just dont like the feeling of torque dropping off.
Hmmm havent heard of that?? Any more details? We tried all the studs to reduce the size of the wastegate path to hopefully increase boost up top but couldnt do it. I think my intercooler could have been restrictive.
Yeah talking about the PU high flow. Sorry your right Stao made 295rwkw on 18psi and 305rwkw on ~21psi.
there are two alen keys next to the flapper, did you try those?
it could be that you are getting so much volume through the mid range that you cap it out early and cant do anything about it.
either way your results are already good lol
It wouldn't be dropping off any more than it is now, I guess the slope would be steeper, but you'd still have more power/torque under the curve.
The torque curve was pretty wide on mine and abes. It Might have some thing to do with his return flow cooler. Thats the one went burning hot after 1 run and took 3 mints to cool.
Is that correct? Hareys cooler got hot after just 1 run?
If so you should definitely change that mate, that would be holding you back a long way.
You talking about my old intercooler Stao? Didnt know it was that bad? Anyway I changed to an ARC return flow when I changed to the SS1 turbo. So unfortunately cant directly see the difference, except Trent said after 15+ dyno runs the temps were excellent.
Not Jeffs. The other car with the G3 has a made in china return flow that went burning hot after 1 run and took agers to cool. Buy the cross over ones like mine with a decent 600x300x75mm core. That gives the best performance.
Tao, I wanna come past tomorrow and talk to you about high flows / get you started on one for me, as I'm biting the bullet on getting one. When is a good time?
Highflow? Get a SS1.5 PU. Be a man. Do da right fing.
After talking to Tao and testing his car, we've arrived at an SS1PU highflow as my choice. Stock looking compressor housing with modest power and hopefully only a little laggier than the standard turbo. Was very impressed with the Taomobile's power, the thing just wants to eat gutters above 4500rpm in any gear, but it's a bit laggy for my liking and daily driving. Can't remember what turbo he had fitted, but I'd rather more useful power and hopefully the SS1PU fits that bill. Will post results when I get installed and tuned :thumbsup:
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
