I think Tao's latest version best suits you Birds.
Its called the hyerdrier. Nice high power air out of the intercooler pipework to dry ya hair and NA goodnes. All 90rwkw!! Blistering.
Stao what turbo did Birds test drive? sounds nice
Some people prefer the meaty feel for a daily drive, I wonder what final output it had
Good work Birds.
Be interesting to see your results and impressions.
May make me tempt to get one too :/
Ur going to be playing catch up. Rob and Simon are going OP6 highflows as well. Both on 33's
Honestly people are always supprised. Highflowing gives the standard housing some real balls.
LoL. Power of dreams with a blast of worm air. Here's the result of Turbo Vs NA:
The VCT plug fell out and remain unnoticed. Below is with no VCT:
LOL O RLY?!
A turbo motor without a turbo SUCKED? Who would have thought! Stao today you have earnt your masters of rocket science!
Lol only kidding mate, funny thing to see - thanks for sharing haha
Good work Birds.
Can come drive it when I'm done ;)
I grabbed a SS1PU from Hypergear and it's been fitted to my R34 making 340RWHP, Damn does it make a difference, comes on solid and holds till redline. Cheers for the hard work on the turbo will keep you updated on how it goes on the track on sunday.
Got to be happy with that, a nice figure. Stao made slightly more on 2-3psi more boost but I doubt it would be that noticable between the two cars.
As long as its coming on as early as it should that should be one very quick skyline
I wonder what it is with a lot of these hg turbos not makin its desired power, ie with this turbo of 280rwkw, is it because of the IG and small actuator, as a lot of the car setups seem ok?? 340rwhp is more like 255rwkw, which is pretty short imho. Same power as some hiflows.. Stao's car seems to make great results tho, I'm saying cos I'm wanting to get one of these- HG or a Kando myself, just that some results seem disappointing.
Will i NEED a G3 to make at least 280? Thats what it seems like, to go one power level up to be sure of making the power level below it. I do not want the lag of the G3 to make 270-280 plus. And then reading the Garret threads, some of these guys are bored of the 'slow' 270rwkw and going for at least 300-320 on a road car...wtf??? I thought 270-280 is the sweet spot..
Choosing a turbo to suit your taste is best done by sitting in cars with them on, they are the hardest choice determined best by TRYING diff turbos on..not reading forums like me. Just my 2c. But i must say i like the lightswitch like power delivery of a tractor spec SR20DET S15 I drove once. True the initial lags not good but the sudden shove was great, it was a jap spec silvia, stock turbo, high boost. The RBs feel much more torquey down low and much smoother n more gradual power shove, which i find boring....but minus the nasty tractor noise... :)
The turbo is just a part, the control result is based on a car that has no restrictive or EPA components, healthy engine, quality supporting mods, tuned by one of the best tuners, so it should be the best as you can get with the turbo that is on it, control results are very achievable.
He already answered to that. and how welling are you making your car road legal?
He's also saying the results you are seeing are the maximum power can be archived. So SS1PU maxed out 280rwkws on 22psi, and 255rwkws on 17psi. G3 maxed out 330rwkws on 23psi and 280rwkws on 18psi. PU maxed out 303rwkws on 21psi, and I'm making 287rwkws on 19psi.
Depending on the mods you are welling to install, as well as the amount of boost you are comfortable to run.
Edited by GeorgesR34
It's just a number dude, don't get so hung up on it lol. In reality, a car with 280rwkw may only juuuust get ahead of a car with 260rwkw. There can be huge differences in power and the reality of it is that there won't be a massive difference in how they feel or how quick they are, it's milliseconds.
My tuner decided that he didn't want to run it at the 21 psi it was set to run he changed the preload down so it is at 17 psi, He confirmed that the numbers it could make were well above what it is now but he would rather wait till I do the metal head gasket as he isn't comfortable with running more than 17 psi on a stock motor.
It will be fine.
simon was running 25psi+ for months at the track with a big turbo with no issue
Edited by Rolls
As others have said, you have to expect variation in results because every car, tuner and dyno is different. I didn't buy the turbo expecting my car to make the xxx rwkw that other cars make with HG turbos...if you do you will probably be disappointed, because there's a lot to so to extract every last kw out of the turbo. Tao went through with me the mods I should do to expect the most power. My goal is to keep my car looking inconspicuous and the trade off is that I may not make the power that a much more illegal looking car will, I'm content with that.
If it does then that's just a bonus of bragging rights, and if that's what matters most to you then you might as well go for the laggiest, number producing turbo you can get for guaranteed dyno queen status. I care more about my 0-100 time and drivability...I need useful midrange power, so as long as there is a big improvement there, then it will have been a worthwhile experience for me.
When people say they get bored of 270rwkw etc. these are usually the people who like the come on strong power, and if you're one for that, then yes it is easy to get used to the pull after a while. But there are plenty of these people who regret going higher and wish they'd stuck with the turbo they had before, after seeing how useless the extra power is on the street and the response sacrifice they've had to make for it. There's only so much you can do with big turbos and an unopened RB25 before you're no longer increasing the area under the curves and instead chasing dyno queen numbers or wheelspin in every gear at 11ty rpm.
And remember...255rwkw is before you introduce E85 to the equation...which can easily net you another 30rwkw+ and a better midrange. That's why I went for the SS1PU, because I didn't see the point of buying one that makes a laggy, wheelspinning 300rwkw on PULP when I can swap to E85 and do this with a more responsive, linear turbo. I'm excited!
The head gasket comment by the tuner is rubbish, the standard nissan head gasket has been proven to huge power with aftermarket engine builds. Lots of tuners prefer them over aftermarktet metal ones.
I understand if your tuner is worried about the standard engine overall. Does he have much experience with skylines? A lot of tuners that dont are hesitant to boost it too high as they are not aware of how strong they are.
Give it hell as it is for a few months and then take it back and demand the boost be raised :)
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
