Finding a good tuner is hard, but finding one who actually wants to do it properly everytime is even harder.
This is more the issue, I found good tuners but they were lazy and rushed as they had too many customers half the time and I couldn't trust they had put 100% into it.
When they had no cars they did a top job.
Its all business mate, money comes first for most people..Its a sad world really.
My own car was tuned by one of the biggest names in this country, admittedly it wasnt in good shape at the time but the tuner more or less tuned it to whatever and sent him packing (previous owner being a mate of mine).
IMHO this was a half arsed effort and shouldnt be the case. The owner was somewhat naive and didnt realise there was any issues, he trusted the tuner to report back anything they found (as requested). The tuner believed the cat was blocked, thus they punched it out for him as a test but still had a bung result.
They finished the tune as is and gave it back to him saying it was fine. I found the middle muffler was blocked, once removed the car instantly picked up bucket loads of power but only made it to redline once. Knocked so hard it blew the motor.
Not the tuners fault the motor blew, I should have known better but didnt care. But the tuner definitely let the old owner down by giving up after the cat wasnt the real issue. Again, biggest name I know of (internationally known).
This is why I'm not going to a big name tuner, I want the best for my car, but don't have thousands of dollars to plunk down on the table and get their attention.
Luckily Ive found a tuner where tuning is his hobbie and he also has bucket loads of experience to go with it. He doesn't really tune for money (thought he does charge of course) but more because he enjoys it, lets you sit in the car and explains everything he is doing and won't finish until you are happy with the result.
If you just want to give him money and pick it up he isn't really interested in tuning as he doesn't get much of a kick out of generic jobs if you aren't actually interested in what is going on.
I find if you have a bit of a relationship with them, eg have been there many times in the past and they know you on a first name basis they are far more likely to give it 100% of their energy, even better if you are a friend of a friend as they feel more accountable that way.
Agree about tuners, can't blame them a lot of the time when they have to compete with each other for bottom dollar customers...and lets face it...there are plenty of tight asses out there who will go with the cheapest option because they spent x on their turbo setup and didn't budget for a quality tune. It's not a mechanical repair where you can say it will cost x dollars, then when it's repaired it's repaired and it either works or it doesn't. Tuning is a quality/time equation, so obviously the more time they want to devote to it, the more they can perfect the tune. They are a business like any other so find an honest one and tell them you're willing to pay for the extra time put into making it right.
Hey guys where abouts is the SS1PU listed on the website?
I have been trying to find its prices but cant seem to find it.
Also does it bolt straight back onto an R33 RB25 or will I have to have anything customer made?
What type of things have to be customer made
Thanks :thumbsup:
One thing you need to do regardless of the turbo is a solid intake pipe, preferably with BOV and cam cover inlets. You can get away without it but your results will not be optimal and it is not recommended.
Edited by Rolls
Hope so.. it's going in a 32 too ;).
http://digi-hardware.com/atr43.html
I'm guessing I want a g4 in a .82 housing.
Profile G4 T3 .82 / 1.0: 600HP $1250
No way...too laggy for the power you want. Keep in mind the factory turbo is good for up to / around 220ish, if it were possible to reliably run that on E85 you would probably have your power goal. I'd go for a highflow that mimicks the factory turbo in terms of response, but with stronger internals. Or the G1 profile.
LOLZ how did you come up with that turbo?? That turbo would have full boost a fair bit over 5000rpm. Why not run a GT45 turbo on 0.2psi...
As birds said, you want something much much smaller. Either a highflow or an SS1.5PU would be my choices.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
