But then it would be boring..? :O
Sif, im sure a 220kw R33 is a pretty fun car.
Put it this way, it leaves a lot to be 'driven' rather than to be 'feared'.
how much to highflow a s15 turbo and what could be expected out of it? i did a read but would like to hear first hand and yes its for a sr
Can high flow that to some thing similar to a 2860 or 71 with good response and drivability. Can also high flow them in to G3 specifications which one member in NS made 290rwkws on pump 98 with, how ever its bit laggy for a SR20det.
Bit update on turbine designs, I'm working on another model based on .82 G3s by keeping combustion circulating longer inside the turbine housing before final exist, hopefully speeding up turbine wheel at higher rpm without increasing combustion pressure. If every thing works according to plan this method would deliver even better ending result then the current fnt setup.
Tsk tsk...you really should know better dave...looks like i gave you too much credit.....
trying to see your point but i'm guessing you don't have one :).
I think Ron may have gotten confused, because Birds said he was getting a SS1PU but then later he said hows my high flow going :D
I was slightly confused too
If I'm correct in my guessing, I'm getting the internals of an ATR43 SS1PU put into the standard turbo...so it will have the standard comp housing bored out to suit and look factory, but the aftermarket rear housing with FNT.
So will this make bit less power than ss1PU but with bit better response?
What Is the spool point 4200 for 290 I would be happy with 4500 kinda have to expect that type of thing
Should be much the same, maybe a little less...I don't think the ATR43 comp housing is much bigger than the standard comp housing, if at all. I just wanted a more factory look so got Stao to high flow the factory comp. The rear housing is the same as the ATR43 so this is why it should produce similar results.
Apparently my turbo is now ready so I'll pick it up, install next weekend and get it tuned soon after.
OK, dont get confused..... Stao can highflow your turbo, its called a highflow...
Stao also does what he calls a PU highflow, which is pretty much the same as your regular highflow but stao puts a bigger rear housing on it.
The rear housing is similar to whats on the G3... But it will retain your stock front compressor housing. I believe it comfortably maxed out at 290 or so.
Ahh how nice it would be to start back at a stock skyline.. Simple highflow, cooler, zaust, tune. How nice it would be :rolleyes:
Whats the difference between the PU hi-flow and the G3?, i actually thought they where exactly the same except the the G3 comp cover is a big GT30-35 .70 one instead of standard.
But then i don't actually know and have never asked..lol
cheers
darren
Can someone correct/ clarify me:
Hypergear equivalent or closest match to:
Kando T67 = G3?
GT3076R = Kando TD06SL2 20G(10cm) = SS2 or G3?
GT3071R = SS1PU
R34 Hiflow / GCG hiflow = SS1
Kando T67 = G3?
GT3071R = SS1PU
Very gross comparisons.. I dont even want to do this but here goes:
T67 = 35R (will be similar in power on the average setup, on a well built setup you can expect more power from the 35r but more response from t67)
3076 = G3 (G3 will be laggier)
3071 = G2 (3071 may make more power)
2835 = SL2-20g/SS1PU (2835 should be laggier, final output about the same)
GCG/GTRS = SS1 (the staple 240kw products)
Please pick something now and but it lol
Thanks man, interesting how they compare, where would you put the ss2 btw??
I would put the SS2 with the 3076. Both turbo's capable of 300rwkw, with the SS2 coming to full boost by about 3500, tad earlier than the 3076. I would have compared the G3 more to the GT35 turbo, it has potential of about 350rwkw and it won't make full power until about 4krpm...
The GT35 on an Rb25 motor is capable of about 450hp to 500hp. The G3 sits around there 450hp and with a bigger motor a little more. Its not a direct line but I certainly would not compare it to a 3076.
Thats what I thought, as per my original post, ie-
ss2 = GT3076
T67 = G3
Hey Sarge did u get your missing kilowatts after you fixed your intake pipe?? How much power u at now?
any reviews on the 50mm hyper-gear gates you sell?
The Silvia you see on youtube has one fitted and running for the past 5 years. I occationally uses them on the test car, works fine. Internal wise I've machined them to run on dual springs fully adjustable.
Size wise G3 is one trim larger then a 3076 with 2mms bigger in comp inducer and turbine exducer. I think might also be an slightly bigger turbo then a T67.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
