Definately. I have another 2 hypergears to tune soon. Well 1 until Kasko buys his ss1
You'll most likely make that 3 soon, I called you Wed night - still pretty keen to let you tune the SS2 on my auto GTT
See the way I see it if you are running the max airflow a turbo can provide at redline, then that same airflow at x psi will be x+y psi in the midrange, hence you should run more boost in the midrange to make the most of the turbo.
Like if you look at the compressor map then the same airflow at redline at 20psi is 25psi in the midrange. So if you can get away with running more boost at redline, you should increase the midrange boost to make the most of it.
Which is why I think turbos should be set based on airflow not psi. Though if you do it this way you are always going to have a massive midrange spike and have torque fall off by redline which just doesn't feel as good for some people, though for drifting etc it is perfect.
Thoughts people?
Well for a start you will have a LOT more cylinder pressure around peak torque, where you don't want it..
cheers
darren
Edited by jet_r31
Look at the 3L TT inline 6 BMW engines, all sorts of trickery to keep the torque flatish and not have massive peaks like our cars.
But the sharp rise is what makes a fun street car and makes passengers grab the jesus handle. ;)
JET 31 - Why dont u want maximum torque? Thats the funnest part, yes its more det prone there but if the fuel is good enough then there is gains to be had, then let the boost build to redline and make crazy power figures.
If only...
Tao i agree, E85 is cheating. 98 is the devil.
I think its more to do with the wastegate gate setup. When Trent did the internal and external gated test, the hug drop in internal gate setup means the turbine is cooping with high exhaust manifold pressure as well as heat after certain rpms.
From experiments that I've conducted a large external gate acts as a secondary turbine that carries out compressor flow only when needed.
So getting good results from an internally gated setup: Comp flow = turbine flow
on the external gate perspective: Comp flow = Turbine flow + External gate flow.
As if I run G3 compressor onto a SS1PU's turbine with a large 60mm external gate, I should get the 300rwkws peek power from the G3 while having the 20psi by 3300RPMs response of the SS1PU. I will do some tests on that when I’m over with stockie boltons.
cheers
darren
You always have peak cylinder pressure at peak torque... that is what peak torque is. What I am saying is you can increase your midrange torque for any given redline torque if you are running flat boost. Assuming of course you are not limited by detonation due to fuel etc.
Tao i proved exactly what u are saying with my old sr20 and .6 disco potato. I changed it to a 50mm external gate setup and made an extra 15-20kw all over. Its amazing how much extra the car can breath
If only...
its a traction thing..its the way the max toque is delivered..
I know my with old turbo came on so much smoother with a factory airbox even ,just putting the pod on it would make it snap noticably harder into boost/max torque making it easier to lose traction ,which is fun but I prefered the smoothness and tractability with the airbox, even if it was making a few kw less...I could feed power on hard without slipping around or kicking out so much..
Guess it depends if you want to slide or drive..
Ur on ur own with that one. I see it as even if u have the power to break traction, with the correct throttle control u can be just as fast
IE me and you testing animals in the rain lol
Im just sayin it was a little easier to drive, not as much skill needed just smash it and go...
Sure you can do anything with "correct throttle control" but hey, if you have skill you dont really need synchros in your gearbox either...but they sure do make life easier...lol
Some Modifications that I've done to a stockie R33 21U turbo:
4inch inlet adaptor with SS3 comp wheel:
Looks all sort of stock I guess.
Would be awsome if I can crack 300rwkws with it internally gated on pump 98. :D
does it really need to be 4"? lol
cant it just be 3"?
Nope, the comp inducer is larger then the 2.5 inch inlet they had there. Had nothing left to clamp hose on after machining. lol
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
