JET 31 - Why dont u want maximum torque? Thats the funnest part, yes its more det prone there but if the fuel is good enough then there is gains to be had, then let the boost build to redline and make crazy power figures.
If only...
I was just talking about using 98 octane, not unlimited octane, would be a nice old juggling act with timing on 98..lol, i have had freind long ago just do this with WI, standard T25G;s
on Sr20...25psi coming on and through midrange and 16- 17psi up top which is all it have it give, 111-113mph traps on a T25G in a silvia ..not bad..
cheers
darren
Hey guys
I'm working on a 250kw RB25 setup
Tossing up between the ss1pu or the ss1.5
It's going to be a street car and I want something that pushes you back in your seat and makes you hold on
Makes power early and can hold 250
Read the charts with the differences between the 2 and saw the 1.5 made better numbers on lower boost so I guess this would be the way to go?
What's the difference in the 2 other then the $250 price difference?
http://i.imgur.com/WxXlQ.jpg
definately gets the 'whoa!' feeling :)
Ur on ur own with that one. I see it as even if u have the power to break traction, with the correct throttle control u can be just as fast
Not with a Gt42 and 400+ wkw and 200rwkw of that over say 500rpm of the powerband coming on ..,lol its so toey it impossible to control and the faster you go, the worse it is, because you are applying more load and need far , far less throttle input, all you can do is setup sus and tyre selection
cheers
darren
Edited by jet_r31
Thought i would chime in with my findings so far on my ATR43G3.
Firstly, hats off to Stao and his mechanic that can get one of these suckers fitted in 4 hours!
Took it for a little drive around the block. Using 1/2 throttle, i got it to 4500rpm 1 or 2 times just to see whats up. A nice spooling sound and exhaust note is whats up! It seems to run/idle the same as before (tuned ECU), but i know not to give it the beans until its tuned properly.
Changing injectors tomorrow so if all goes well its getting tuned on monday.. Then drags on wednesday. :devil:
Would be good to see some mph from these things!
cheers
darren
You're not gonna try to drive it to Ovaboost after doing the injectors are you??? I'd bring a couple sets of replacement spark plugs if you are :P
Also keen for results from the tune/drags :D
Lol, i've since decided to change them in their car park. :thumbsup:
Edited by LANDSCRIBBLE
assume the wheels, shaft, bearings, and housings are re-useable. That will cost you $400. If every thing are gone and only housings are good then its not suitable for rebuilding. That will cost you $800 which is high flowing to 2860rs specifications. So the worst case scenario will cost $800.
Hey Stao,
What would be the highest figure you could expect from a SS1PU without putting to much stress on it?
I see its rated to 470HP which if I am correct is around 350kw
I am looking to purchase on this week.
Thanks
SS1PU makes around very responsive 260rwkw mark running 18~20psi. 22psi max it out at 280rwkws which is the most this turbo can do internally gated. This turbo has no issues handeling boost.
For the GTiR rebuild, $400 covers: 360 degrees thrust bearing, bush bearing, collars, seals, sand blasting, balancing and assembly.
Drop the turbo in when ready. I will need to pull it part to give you an accurate quote.
Some Modifications that I've done to a stockie R33 21U turbo:
Would be awsome if I can crack 300rwkws with it internally gated on pump 98. :D
Turbo's installed today:
Looking pretty stock :D ?
Initial test drive, it builds up boost very quickly. Dyno tune due in soon.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
