Oh and after I get my SS1PU tuned on PULP, I'll be seeing what E85 can do in the top end for the response monster :)
I went with the G3 because it makes more torque at each rpm increment than the SS2, and it makes more power under the curve (don't just look at boost or response here, the G3 is making more power everywhere than the SS2). The SS2 only catches up in the higher rpm to make the same power, the G3 beats it everywhere else, even if it's only just.
On Stao's results anyway, I haven't got those results yet.
Attached Stao's graph of G3 vs SS2,. they are so identical - I do not look at the boost response as you saying - I look at the power it is making at rpm points - 2000rpms, 3000, 4000, 5000... At the first three points the SS2 is clearly making more power hence more responsive and better for the street, but the G3 catches up around 5000rpms at 260ish rwkws and beats the SS2 from there but not by much. The SS2 also makes significantly more torque at these points too and peak torque is hardly different between the two.
So I still dont understand why the G3 is more popular with you guys apart from the cost..pinch.gif
Haha yes, it's like that now. Read back through the thread, there have been multiple changes to the G3 and SS2 that have affected their power curves since I bought mine, the graphs you are comparing are the latest ones. I will see if I can find the graph that I used to compare the two when I bought mine. The G3 kills the SS2 for peak torque however you look at it though, not sure what you're going on there.
One of the other main reasons I went with the G3 is because I track my car, so heat is a very important factor for me. Stao mentioned that the G3 was not getting hot at all during tuning and he was running it as high as 23psi. For sure I would have gone the SS2 if my car was purely a streeter, but I took different things into account such as the high rpm performance of the two, heat factors, etc. etc.
Cost was also a factor I'll be honest, Stao sold me the G3 that came straight off his car for the same price I was able to sell my old G2 for, so the swap cost me virtually nothing.
Edited by Hanaldo
Makes sense now - G3 would be better at consistent high rpms/ tracking due to bigger exhaust housing (laggier?)...Cleared that up for me now thanks - as for peak torque G3 vs SS2 = 514Nm vs 497Nm - hardly much to go by..
I'm more worried about heat soak and super-heating of the intake charge. When you're at a consistent high rpm (I don't think I was ever below 4500rpm on my last time out) around the track there is obviously going to be a lot of heat. As I don't have an ECU capable of pulling fuel/timing based on intake air temperature, I wanted to avoid super-heating the air and causing detonation.
Does that mean the SS series turbos SS1, SS1PU and SS2 are not ideal for tracking due to their tendencies to heat up real quick (small exhaust housings, high boost etc) at constant high rpms?? :wacko:
I wouldn't go as far as saying that, but the name SuperStreet sort of gives an indication as to their intended use don't you think? ;)
The SS series is more than likely fine for the track, I'm simply paranoid :P I looked at two turbos with very similar performance, one looked more suitable than the other for what I wanted so I went with that.
Don't forget that these turbos are forever changing and gettin better though, it's like buying a mobile phone. You buy the top of the range model when it first comes out and 6 months later it's redundant. My reasons for buying the G3 possibly don't apply anymore.
Ive been away since the start of this year so did not have time to troubleshoot my lack of power and finish the tune with my SS1PU. Finally back home and having the car sorted out tomorrow. With some luck I hope it wont be too hard to work out the power loss issue before completing the tune.
Any more? ;)
My car is on the dyno right now. Major boost leak was caused by the rubber intake manifold gasket... cant wait to see how it goes.
I bought the SS1PU specifically because Stao said its a cool running turbo, good for the track. Hopefully this is really the case.
I think the SS1PU is a good thing all round, stao has put some hard effort into it and it works well.
looking forward to your results.
Temperature is a function of boost remember so even if you get the smaller rear housing turbos as long as you don't try and push 25psi through them on the track on BP98 you will be fine.
Ultimately setting up your ECU with coolant temp and intake temperature fuel and ignition trim is the ultimate way, even better if you can trim boost as well!
That way you can tune it to run 25psi on the street and as soon as it starts to get hot on the track the ECU will automatically adjust to keep it safe.
Ive noticed the effects of heat soak on my car but that is generally after big drives(2hr+) on hot days. Not so much detonation rising etc but just doesn't feel as... oomphy when shit gets too hot.
That is just heat soak killing performance by heating the intake charge. You won't notice heatsoak in the turbo etc, you will just be slowly removing your margin of error for detonation until it gets so hot you detonate, and you don't always hear detonation as well so be careful.
I always advise people to do two tests, one is on a warm day eg 28c give the car a good flogging then immediately stop without cooling it down and idle around at 10kph for a good 10-15 minutes getting massive heat soak, then go rev out 3rd gear once again without cooling it down. If it is going to detonate due to intake temps it will do so then.
The next test is to just do high load dyno run over and over again to get the turbo/manifold red hot. This will also usually cause detonation if you have a small turbo that really chokes up.
Result for my SS1 PU are in:
Overall its not bad but not the best
-Peak power 244kw
-Makes about 200kw at 4000rpm (good, expected)
-Boost goes from 21psi in midrange to 17psi in top end
-Tuner reckons something is holding it back since its doesnt make that power in the top end easily however he is not sure what it is
-Tuner reckons that it comes on too hard with the current actuator so they had to massively reduce timing (which he is not happy with) so it would not ping in the mid range
-If they use the EBC at all there is too much boost low down so they are not using it
-If it had a lower pressure actuator he thinks they could run lower boost and more timing down low, then higher boost up top and more peak power
I will pick it up tomorrow morning, tuner had not yet driven it when i spoke to him.
He thinks it will feel very fast and pull hard so it may not be worth chasing more top end.
The ss1pu has a pretty large turbine housing, that model gains response from fnt turbine and lightened billet machined comp wheel. It was pretty happy on 22psi on mine, shouldn't have any issues downlow. Might be interested to find out what's holding it back. ill have a chat with Trent regarding to the tune experience, Keen to see few more results. Also i can supply a 15 psi actuator to run ebc with if you are keen to twick it bit further.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
