i guess i do. im just going by that chart, that says the G2 is rated for 450hp (not sure if its @crank or @wheels)
The chart say 450hp - that is not 450rwhp.
450hp is @ the motor... ALL turbos are rated in such a manner
You can check for a OP6 rear. We will have the the bigger rears soon. The engineering place just take their time doing it. Hopefully be available in Mid May.
Hello Stao!
I have a vg30det turbo 4V54 front with OP6 rear sitting in the shed. I would like to no how much for a high flow? it is for for my RB25DET Cefiro street car so i'm trying to keep resonse in mind while still achieving as much power as possible. Having said that, wats gonna be better ball or bush bearing?
The high flow will cost $800 plus $80 oil feeding line. We will be using ATR28G3's profile which should get you around 260~270rwkws (OP6 rear) with supporting mods at peak and not too bad down low either.
Edited by hypergear
With R33 stock housing its very close to its limit, maybe another 5~10 kws once leak fixed.
With RB20 turbo's high flow I'm not too sure as I haven't had one dynoed yet. I guess its probably archive close to 230rwkws.
Wheel size wise this is using the a 71mm comp with 65mm turbine. With Garrett GT2871Rs its running the same size comp wheel but 53mm turbine.
I'm guessing you mean 71mm comp with 56.5mm turbine. I guess you use this on the larger rear housings as the stock R33 rear housing isn't large enough?
Would the larger rear housing turbo be suitable for a remapped ECU R33 car if only running 9psi? (currently runs fine on 10psi stock turbo)
As a replacement for stock turbo until I get off my arse and get injectors, AFM and powerFC?
We do use 65mm Turbine. Need some thing to flow as possible in a small turbine housing. If you can get a OP6 turbine housing we can use ATR28G3 CHRA with 76mm comp wheel. That will be able to get you over 250rwkws. You can drive it on low boost no problem, as for the best results get it dyno tunned with Power FC and supporting mods.
As for RB20 using ATR28G2 hi flow you can probably get some where between 200 to 230rwkws.
Edited by hypergear
Any way adding some photos of the OP6 reared hi flows.
This is a complete ATR28G3 high flowed into a OP6 Rear housing (note the mark on the housing)
GT2871RS CHRA high flowed into R34 OP6 Rear with stock comp housing:
This is a Custom made GT3076RS in a .63 Rear internally gated setup bolton to stock Manifold
Edited by hypergear
Will the larger rear be 0.7 A/R with skyline bolt pattern? I want 230rwkw at about 1 bar or less, I'm thinking a 2871 would get there easier with the slightly larger housing.
Is R33 rear housing 0.58 A/R?
And where did these 0.7 A/R housings come from? Couldn't they have made them 0.82 or something to flow a bit more?
Edited by simpletool
The larger rear would be a .63 rear with RB25's bolton pattern. If you perfer 230rwkws BB GT2871 CHRA should do it fine. You can get that with stock turbo's rear housing. Stock R33's rear is only .48
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
