Can you give me a quote...
Ive got that 300zx VG30DET turbocharger that i posted earlier, what would you charge for a highflow option for this?
got my car tuned the other day, and seems a tad restrictive, so i think in the new year ill go for a highflow!
also, the internal wastegate isnt holding boost down, its opening at 7psi, then it climbs to 10-11psi by redline.
this turbo is strange, cos the internal wastegate is behind a flap, as the turbo outlet is a 4 bolt, so it cant flow enough gas out to hold boost down.
what options do i have there?
heres a pic: DSC01066.jpg
Thanks.
Pinched that pic from your build thread, if you remove those shiny bolts and removed the plate im assuming you would be left with the standard vg30/rb25 flange and your wastegate would work a heap better but you will need a new dump flange, looks like some has used that plate coz it would be easier to make a dump flange for it.
Edited by W0rp3D
Can high flow that to produce about 500HP. The cost for high flowing is $880. And $150 additional if you need the high pressure actuator.
You need to send this in asap if you want to get it done before xmas.
The engine originally had 5 cracked pistons through the ring lane area. So I replaced those pistons with a set of brand new OEM pistons and rings. I got them for $500 off some one who bought them and ended up forgies. The engine noise you heard earlier was gone straight after rebuild.
My boost gauge has scale for of 20psi so I guess the tuner wasn't be able to read it if its above. So he said 21psi as the niddel stops there. It was running a ATR43G4 which is identical to a GT3582R in .82 rear.
Well its worth spending $3500 to find out the actuator that works. All for science and my customers.
your customer service is second to none i will definitely say that. I don't think i've had an unhappy hypergear customer through the shop ever. Let me know the results once its back together.
Stock turbo removed yesterday, went to start bolting up my ATR28G4 and none of the oil/water lines fit. I need to clock both housings 90deg. If i do this my self is the warranty gonna stay intact?
There seems to be a bit of a mis understanding with "BOLT on" statements made about HYPERGEAR turbos, the only BOLT ON's are the highflows the rest require, clocking, fabrication and DIY mods like water and oil lines.
The only part that bolts on is the 4 turbo to manifold mounting bolts.
All lines except the oil feed should bolt up. I have the braided oil feed. Just wanna make sure i can turn the housings without having to send the turbo back.
I would agree 100% with this... If I have ever had a problem he is straight on the phone to me trying to come up with a solution!!!
very good business ethic these days is hard to come by
All the water llines and drain fits. The only thing that doesn't fit is the the feed which we supplied the oil line. If its not at your bolt up position just losen up the bolts and rotate the CHRA by few degrees.
All fittings will go in with no modifications.
The older ATR28xx with T3 .63 turbine housings was like that as the CHRA was made to bolton to a CA18/SR20's manifold and fittings. This has been changed in later models for T3x customers.
The ATR43's had the water line wholes drilled to M18x1.5m, with T3x Drain pattern, plus thread to suit braided oil line. It also has a customized turbine housings in .63 and .82 made to bolt up to stock 6x bolt dump pattern. This turbo will bolton to RB25's manifold, dump pipe, fittings.
For Crans:
Yes. Just loose up the bolts and turn the CHRA. Once done tight the bolts back the way it was. Then spin the turbo wheel it should spin freely.
Cant wait for my new turbo 3582 .69 exh with 50mm gate and anti surge slotted .7 front cover
ill let u guys know how i go once its tuned after the new yr
gonna be a bit of an upgrade over the old kkr480 lol wonder if 400rwhp is out of the question mmm
thanks 4 ur good service stao hope to see the turbo in the mail soon!
LOWRB: We are still working on your comp housing. Should be finished Wednesday.
We also make custom 2mm thickness high pressure brass washers for any one who has oil or water leaking issues at $2.5 each in any sizes you want.
Video of making above taken inside our workshop:
Stao still having trouble getting these lines on the turbo. Can I mount the turbo on the exhaust manifold then clock it or will i rick damaging it like that? Tried 5 times so far and still nothing matches up even had it against an old rb20 turbo.
loosen your housing then bolt it up finger tight to the manifold and clock it to the correct position. then tighten 1 of the housing bolts so it doesnt move and remove the turbo to tighten the rest of the housing bolts. do it that way so you make sure you get it done right.
You won't damage it. Just tighten all the bolts once its on there. you will be able to free spin the comp wheel once done correctly.
ya its a biatch to get back on. you have to skin up your hands, swear and drink some booze. it will go on.
i had to 'mold' the existing water lines so they would almost line up. then fiddle with the bango bolts to get them in.
on bango closest to the engine was a total biatch. didnt think i was going to get that one, but i did eventually.
loosen the water lines at the other end if you can, on the 33 there is one you cant really get to. but there is a clip that you
can take off and it makes it much easier. i only had the top two bolts in on the mani while working as well.
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
