Hey guys
Will it do any damage or cause any trouble if I put the SS1PU on without the nistune installed yet?
Trying to work out a way I can get the car to DVS without having to tow it up there.
I was thinking install the SS1PU and then get my brother to wire up a plug for my z32 so I can drive up with the stock AFM then just chuck the Z32 when I get there
how far are you going to be driving, isn't DVS a couple hours away?
It's very possible not to boost lol. If you want to install the turbo before you get it tuned then you don't boost it, simple.
On the stock ecu it will hardly boost before it hits r&r anyway.
I ran my ATR43G3 for a year without being tunned ran it on 7 psi and its ran great just laggy.
Loosen off the actuator so its sloppy comming on boost and you will be fine hitting up to 5 psi on stock tune
Possibly get a base tune by someone in Canberra and let the turbo run in, then go to DVS to get the tune tweaked?
If money is a factor, work out if it'll more $$$ to tow 4 hours or get a base tune here and drive up.
Hey guys
You will be fine. If the turbo is the only aftermarket thing you've got on there, it will be fine. 4 hours of tow truck.... gonna cost you. You can easily drive the full speed limits. Going up to his place is pretty easy, no pressure to floor it or go fast. Once you are on the free way cruise it there. Get all the prep work done before hand(as you are with the wiring) so when you get there and get to the dyno, minimal time is wasted dicking around.
I drove my car to my tuner about 20 minutes away first time. I had all my aftermarket parts in there except my injectors(didn't want to risk the wrong settings). It was running on the base tune with the z32 afm and it was fine. This drive was through start and stop traffic.
I can probably drive my car to the other side of australia at 110km/h without hitting any boost at all. Right foot, control and toot on. You won't hit 6psi unless you actually tried to. You'll be fine man trust me. You will get there faster than a tow truck will and you will have the money in your pocket to pay for the tune or pay for something else when the car isn't making the power it should.
Yeah he is at least 4 and a half hours away which is impossible not to boost
What kind of issues does it cause upgrading from stock turbo with the stock ecu.
Thanks guys
If you boost it you risk detonation, however what you can do is leave the wastegate actuator off so you literally can't boost more than 1-2psi by redline, do this.
ive been driving with my gtx3076 and stockish tune, cant do more than 2-3psi without the engine light coming on, you should be able to baby it around no probs
just change gear at 2500rpm with not much throttle, mine still keeps up with traffic even off boost, just shift up quickly and your fine.
taking the actuator off will make it sound very loud and drive like a dog, atleast thats what happened with mine.:whistling:
The turbo it self acts like a muffler of some sort, bypassing the turbine the exhaust goes through the open wastegate, it will be louder. It will run like arse, but its foolproof and safe if you are worried about foot control.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
