Its a good number. But I cant spoil it for the owner :)
Ive heard very good things, as expected!
Cough *cut price GTRS upgrade*
You too hey? Thought I was the only one special enough to know :(
It's nothing huge, but an expected figure and there's probably room for a few more killerwasps with a couple more mods. Definitely a worthwhile street car upgrade, given how early it comes on.
Were you guys breaking traction in the vid?
easily more then 240kw? not hating but it doesnt really even look that quick.. maybe the video is miss leading.. and lol at breaking traction .. are you listening with your ears blocked n eyes shut.
I'm on a laptop in an office, what do you want me to do, put on some fucking Sennheisers? Speed looked to be going up inconsistently with the RPM, was curious if there was any break in the drivetrain, be it clutch or wheelspin.
On that note, I bet I can film a video of me breaking traction in a car with the camera looking at a blurry view of the dash and you wouldn't know it.
To me the SS1PU is a GTRS replacement with a little more scope for a well sought setup.
That being said, the GTRS is a 240-250kw item with ballistic response. So far the SS1PU is living up to my expectations, and Stao has shown it definitely has the scope for more (which I dont think the GTRS can do 'as easily').
If I owned an SS1PU on a fairly simple setup I would want around 240 and id be happy with its outcome. If I had spent lots of time making sure my cooler and exhaust and stuff were all good, and no valve float etc, then I would want 270 from it. Remember that Stao runs a fresh motor and upgraded valve springs. While it still is a 'stock' RB25 it is pretty much the best a stock RB25 can be.
As Birds has noted previously, the guy has spent countless hours perfecting his test car and knows how to get the best out of it. Dont buy an SS1PU expecting 280kw without LOTS of effort.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
