Just realized they said there was boost control issues so I guess that would be affecting power up top a fair bit as well.
If it was holding boost to redline I still think itd be 250+
I wouldn't expect it to be hitting 270kw on 20 psi with a 15+ yr old motor.
Edited by Mitcho_7
Wait for the charts gentlemen, no point speculating over power figures or what's responsible for them until we see what the engine is doing. As JEZ said, there's probably a bit more in the turbo if they take the time to sort out boost etc. but for now Kasko should be pretty happy and he looks to be.
Very smooth. Boost tapering off = another 10-20 if you can get it to hold without the engine pinging?
Full boost looks like high 3000's / 4000rpm, I'm guessing.
  • Like 1
Need ebc to hold boost up top. I'm testing a little mod this weekend and hopefully that changes the boost behavior up to.
Already got a profec b spec 2 installed in it
This didnt help with the tapper.
Seems the actuators are not up to holding the 20psi consistently
Also as DVS said it seems my clutch is either on its way out or needs a bit of adjusting/bleeding
The car feels phenomenal when it comes onto boost and spins 2nd without hesitation cruising.
Next step is a CAI and a box for the pod filter might help a little.
We did back to back power runs on a safer tune and only lost around 1-2kw
Is that same turbo you have birds?
Yeah man.
How bout that! :)
What size tyres you running?
Assuming it's 4.11 diff ratio and normalish sized tyres is nearly at full boost at 4000rpm with 180rwkw
Not exactly comparable with a GT-RS
180rwkw @ 4000rpm IS comparable to a GTRS, I agree.
Forget about where it hits full boost etc etc. The power @ RPM will tell you what its doing flow wise, which is what counts.
Every decent turbo makes 180-200rwkw at 4000rpm on a RB25... It can be a T67, 3071, 3076 or HKS 2835pros, they all do it
It's what happens before and after then that makes the turbos different!
Edited by SimonR32
Yeah, so doesnt a GTRS do roughly 180-200 @4000 and end up around 250 by 7000? LOL
So its more or less hitting GTRS benchmarks, OK glad we agree. :whistling:
If the turbo can hold boost for the upper RPM, there's no reason it can't make 260-270 IMO, so no it's not comparable to a GTRS...it's slightly better :P
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
