I was always under the impression hypergear did turbos for other cars, but as this is a skyline forum, we only hear about skyline related turbos?
I guess I was wrong.
You are absolutely correct. Stao even mentioned he was working on a turbo for a VW Golf, so I take this as interest in moving towards other markets and keeping with the times. Regardless, Skylines are not over and done with for aftermarket parts...far from it in my opinion. In fact, the market segment for companies like HG is larger than ever, simply because these cars are becoming more and more accessible and they aren't worth spending big money on big brand stuff anymore. I know you guys are just trying to help with your feedback, but don't you think Stao would be doing what you're saying if his current system wasn't working for him? Also, FWIW I didn't buy an HG because I can't afford an HKS, I bought it because I wanted to have some fun with an experimental underdog, not use a turbo that has been tried and proven...I wanted to do the trying and proving.
I'm pretty sure he will still build you a cheap high flow for ~$1000 if that's all you want, but it's not what people want anymore...this thread has had nothing but talk of SS1PU and the G3 over the last couple months, they are what people want. So you got your wish for two models that Stao can focus on improving and I'm pretty sure that's what he's been working on lately. As far as previous customers buying turbos and having them superseded...er...Stao is always offering to upgrade people's old turbos for them with the latest modification at little or no charge. He does NOT owe them this, no other company I know of in this industry will offer to do that for customers and it's a moot point to claim the R&D isn't worth continuing on an RB25 turbo yet claim that previous customers will experience dissonance over their model being superseded significantly by the latest improvements - which one is it guys?
As for beta testing, who cares as long as people are happy with the product. People know what they are getting when they buy a turbo. Yes Stao creates a turbo and puts up a few dyno charts...but he doesn't say "this is the new turbo you should buy" - people practically say "give me that one!" and demand he makes them the same turbo. So what should he do, "sorry can't sell you one, I haven't spent hundreds of thousands on testing it yet..."
/rant
tl;dr don't like it, don't buy it, there's no pleasing some people
lol sorry guys, I don't mean that to sound harsh either, just feel like there's a bit of misinfo being chucked around for no particular reason and I'm somewhat tired/moody (male PMS).
*changes tampon*
lol, i knew you would have a rant...
*Artz goes to look up meaning of dissonance :ermm: *
Haha once you know it you'll use the word all the time.
The RB25det is a good engine for a research ground, results from it can be used to estimate power range from a specific turbo combination on similar sized engines.
Looking back to results generated with the old TRxx series, new series take a giant step forward in performance. Take the ATR43G3 for instance, it had same response as the TR43i but makes 70kws more top end, while the ATR43SS1 makes similar power as the TR43 with twice more mid range, they are not comparable.
The same car's been used for testing and evaluation through all those years, Even running stock engine it was producing similar power as what it is today based on same boost, running hub or roller dynos with 3 different tuners.
The final evaluation figure pre-release means the turbo is capable of making what it made, So the differences could only be in supporting mods and tune. And there are people getting evaluation results per boost level.
A large section of this thread is problem solving and support, it is a good write up in many cases of how people find the problem, sorting it out and ends up with the desired performance.
Turbocharger development will kept on going, we can only come up what I believe is the best during the time been, and improve out comes as project progresses.
I love the turbo btw.
Wouldn't mind the boost issue to be fixed but I will speak to Stao about controlling this.
Everything else is perfectly fine
Most aftermarket turbos with internal wastegates have boost control problems, EBC is a requirement IMO.
Trying to control flat high boost with big back pressure with a simple linear spring is borderline impossible imo because as the rpm increases it chokes more and more so you need a changing gain factor (the spring) which is only really easily achieved with an electronic controller.
The reason a lot of people manage flat boost on garrets is because they are running much bigger exhaust housings where the turbo doesn't choke up as much. it isn't because it is a "better" designed turbo imo.
Edited by Rolls
Kasko please check my youtube video under: taosg2001 for preloading instructions and just check to make sure the gate is tightly shut by the actuator with about 3mms of preload. That will get even better response as the gate don't open as early. This should be the correct boost curve that matched mine
Preloading the spring won't cause the boost to go higher then the preset 20psi will it?
Also will it put at DVS's tune?
If its currently lose then making it tight with about 2~3mms preload won't affect much. But check boost controller once you've done it.
It never seemed loose from what I remember when installing the turbo.
I didn't play around with any of it I just got the turbo in the mail and bolted it straight on.
I'll check this afternoon after work but
Stao, have you thought about fudging your results to show LESS power, that way when people actually make more power than what they were expecting, HG turbos will be all the rage? ;)
LOL thats actually a really good idea.
Under rate the turbo, keeping expectations in line with response and let end users be happily surprised in the end.
Well Kando did have the advantage of being initially perceived as cheap chinese eBay shit lol. SURPRISE!
Talk about a mad troll right? lol
Anything repro' MHI is awesome. Just look at Hyundai!
LoL have a look at the dyno footage, you will note all the runs are pretty much within 10kws or less. That 330rwkw G3 had variance of 5kws pulling runs all afternoon. :blink:
exactly, and if people don't trust status to give an accurate result then we are all f**ked.
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
