Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running our re-trimmed 20G Billet compressor wheel.
It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly.
Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2
Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange.
Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel.
Nice.. Why not call it HG TD06SL2 (Hypergear TD06SL2), thats less confusing..:teehee:
I take it you dont follow the kando thread cause this is what I have been saying for months... :thumbsup:
If you want a ride in my car just PM me man,...clutch is slipping a little atm but should be rectified soon..
Car is very nice smooth to drive
@ 1 bar boost, with 6 month old fuel that was still sitting in my tank.. :yes:
Yea I found it. It looks too linear thou, I pictured it would do some thing that. I should be able to add in lots of meat into the mid range with FNT turbine.
Where abouts are you based? I'm testing the ss1pu again Friday afternoon which we can swap cars for a test drive near status or unless if you are in the North side.
There is no midrange because its at one bar, lets wait and see what the 22psi graph looks like. Hurry up and get that clutch in Artz.
I'm interested to see the results with the stock 5 bolt housing. Get on to it Stao. :thumbsup:
An M35 Stagea rear may work well too... :whistling:
yeah cool, Im near dandy..I probably cant get there till about 6 though will you still be around?
I'll be there 7pm starting the tune on Friday. Its more of testing the wastegate actuator and a newer housing. Should all finish in an hour so its all good if you like to come in around 7pm and see how the tunning goes.
I will trail some externally gated ones including the SL2 and T67 combinations with billet wheels and do some modifications no housings from there.
At this stage we can supply SL2 units in 10cm T3 turbine with billet compressor wheel.
Anyone got ideas about what I should be saving for next to get a bit more put of the turbo
Also how do I get rid of the ping around 250kw
Do things like oil coolers keep the overal engine temp down to prevent this?
Water Meth Injection ;)
better (more efficient) intercooler
Freer flowing exhaust
there are a few things you can do to squeeze every last drop out, but $$$ per HP makes it rather expensive
Save for a plazaman cooler. Or a custome side mount manifold
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
