Or do what I did and buy a cooling mist water injection system brand new of U.S ebay from $280-340 delivered atm with the dollar this good...
something like this http://www.ebay.com....=item1c2551b352
cheers
darren
Edited by jet_r31
Anyone got ideas about what I should be saving for next to get a bit more put of the turbo
Also how do I get rid of the ping around 250kw
Do things like oil coolers keep the overal engine temp down to prevent this?
E85...
Yeah only 2 Servos sell E85 in canberra :(
Daniel, talk to TiTan, he Has WMI on his car, I love the stuff, and it is also on my to-do list
His car that he is selling :(
I'll hit him up tomorrow about it.
Not in a rush as I won't get bored of this setup for a long time. Just good to plan future upgrades
Zebra are u building a 2J now and what car? Why isnt anyone modifying auto aristos?? They have the 2J
I was always under the impression hypergear did turbos for other cars, but as this is a skyline forum, we only hear about skyline related turbos?
I guess I was wrong.
Yes also doing XR6 turbos, VLT, 300ZX, VW GTi plus some electric blow dryers and etc. I can't remember who was asking for results off a high flowed CT12a soarers. I got some results from it:
That was from a Auto soarer.
The thin red line was from stock turbo.
The thick red line is initial tune with the map from his stock turbos
Thin blue line was final tune.
His auto trasmission is pretty much burnt at this stage, should be able to gain another 20kws with a built transmission. They were more responsive then his stock turbos.
That was me...
Something is wrong with those standard turbos?!?!, I see 10psi at <3000rpm on my Stockies on both my old Soarer and my current Supra
Unless Trent was very slowly getting on the throttle to stop it going back to 2nd...But trent is a smart cookie and I would assume he would lock it in 3rd for the run?
Either way very interested if there is a bit more power in it
Espessially if you pick up 4-500rpm for peak boost
what are the wheel specs for those turbos Stao?
Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel.
It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly.
Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2
Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange.
So this isn't the Kinugawa version then? It's another version from else where?
Edited by slippylotion
For the CT12a they are similar specifications as the 2860rs same as what we normally high flow gtr turbos to. He had the stock turbos dyno tuned which was about a year ago and the high flowed ones in just recent. Yes it was in 3rd but with the high flows the transmission can't hold, its slip badly up top.
with the TD06sl2, this is should be identical as Kandos as all parts were bought and made from the same factory in Taiwan. The billet 20G compressor wheel has skimmed hub for greater flow, and light weight, in theory making same effect as our 71mm SS2 comp wheel. The standard 20G wheel is also available.
Since there are working examples I won't go in to very details in testing what has been tested. As said it is now available for $850 as it is with Australian warranty.
In the next few weeks I will turn it into a bolton externally gated turbo for RB25det then apply FNT turbine nozzle to fill in more mid range if possible.
E85 isnt easy to come by where I normally travel to.
Done the coastal regions they don't even know what it is haha
The link to the injector didn't work Darren
I might do some searching on them
http://www.ebay.com.au/itm/Water-Methanol-Alcohol-Injection-Kit-compact-trunkmount-tank-complete-/120885195602?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c2551b352
I prefer pre-turbo, but for my stagea it was to much of a pain to shift air-flow meter to intake and more expensive once i got a bottle etc, i got a 340cc nozzle and expect to make around 350rwkw if i was manual
I;ve tried to do the whole thing with the KISS principle.
cheers
darren
I'll be there 7pm starting the tune on Friday. Its more of testing the wastegate actuator and a newer housing. Should all finish in an hour so its all good if you like to come in around 7pm and see how the tunning goes.
I will trail some externally gated ones including the SL2 and T67 combinations with billet wheels and do some modifications no housings from there.
At this stage we can supply SL2 units in 10cm T3 turbine with billet compressor wheel.
I know a few people who will be very interested in a comparison between the cast 25g and billet 25g compressor... Including me :)
Edited by SimonR32
Stao there are 3 results for the L2 20g in the Kando thread
1 DVS JEZ - E85, gate is too small and cant run/control boost properly. 286, 15psi
2 ARTZ - 98ron, clutch slipped during tuning. 267, 14psi
3 Dori34 - 98ron, NO VCT, surge on spool up. 280kw, 19psi
I will also be very interested if you can make a similar sort of turbo for SR specific application. Such as a TD05H billet 20G, internal gate 5 bolt. The one Kando sells does not flow very well, this might be your time to shine. I can test this item for you, I can strip/fit my turbo in under 1.5hrs and have all the right setup, Jez does my tuning.
Now waiting on a WMI kit too ;)
Very cool thanks
Would love to see a result behind a manual 1J so Trent could go WOT down low, will definately keep an eye out for more results
Cheers
Guys a bit off topic but with the WMI kits, would it be "better" to spend the extra 150 odd bux for a progressive type system as opposed to the old on/off Hobbs switch setup????
Have been looking int WMI for a long time and the $$$ seems anout right to grab one.
Stao, if you can pull off the TD06Sl2-20g 10cm in a bolt on internal gate version that doesn't have any boost issues, it will be a very popular turbo and will get you alot of sales, :thumbsup: to your work
very keen to see the difference the billet wheel makes!
Forgive my lack of knowledge but what is the FNT turbine housing and how is it different to standard?
Its an adjustable turbo nozzle as far as I know, to change the angle the gasses hit the turbine blades.
    • Front wheeled vtec powered rb monster
    • Looking forward to the build thread!
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
