^^^ Agreed.
What are they doing Birds? Fit turbo, fab intake, tune car, there's a day. Why so slow?
He did have that issue with his injectors.
But... It's a workshop. A good workshop, from what I've heard. Good workshops are busy, even simple jobs take time.
Sorry guys, picked her up lastnight and have been busy since. RP were under the pump and down on employees, they have so many cars down there to finish lol.
R33 GTS-T (~150,000km)
Apexi pod filter
Yellow Jacket coil packs
3 inch turbo back
Blitz CS FMIC
Z32 AFM
Bosch 040
Nismo 555cc
Power FC + EBC kit
HG SS1PU custom (Nissan comp housing instead of ATR43)
258.6rwkw @ 16psi on Shell V-Power (98)
Second line is a slightly safer tune with some pulled timing and more fuel, making 252.4rwkw.
And that’s with:
An internal wastegate
Nissan comp housing for a standard looking turbo
Cat and Varex muffler (Varex supposedly costs you power, I disagree personally)
Return flow FMIC
Standard intake hose
Standard BOV
Comments: This all makes for a quick, responsive and standard looking street car. It is lovely to drive in daily traffic, better than standard. Stao warned me that I would be down on power due to the above restrictions, so I daresay there is potential for more in the top end and all over the place…but…my aim was to make it fast and keep it looking stock (see pics below) with a very safe tune. I think we’ve achieved all that! Thank you to Stao for a great turbo and Race Pace for an awesome tune.
Will be throwing the standard airbox in when I find it, so that the boys from the EPA “can’t touch this”. Oh and…stay tuned for E-flex :)
Good result Birds, is that pretty much what was expected? I'm not sure how the standard housings compare to the ATR housings, but 260rwkw seems like that's about right?
*EDIT* Same time post haha, sounds like you achieved what you wanted, well done man :) Gotta get this plenum and new fuel system done on my car and get it back on the dyno without the ECU problems now! :D
Edited by Hanaldo
WOW. For such awesome results it is so surprising to see how basic your setup is.
I love the fact you did so well with the stock nissan comp cover, rubber intake and stock cooler piping! Those all would hold it back from maximum potential in my eyes, and you did really well!
Props to all involved!
Nice graph man, I see you still have the standard rubber intake.. Not sucking shut? Maybe 3-5rwkw to be gained there by going 3 inch metal..
Speaking from experience? ;)
Lol thats a pretty awsome result there birds, Looks so stock. I too would be worried about the rubber intake sucking shut though, with all that extra suction its creating now. At what psi is it getting 16psi?
I thought you mentioned sometime back that your $400 intake pipe got you approx 3-5kw? :P And your HKS sticker on it made it cool.
I'm really looking forward to when (or if) you finally commit to modifications, it will be good to see how many corners you cut to make it cheap and how many times you will spend more money than you thought you would, as those of us who have actually done it can tell you it's going to happen. It's gonna be a real blast.
Speaking of things that actually happen, that reminds me; Birds didn't you say RP were making you a custom intake pipe???
Edited by Hanaldo
Yep, well more than expected to be honest. It's not far off Stao's figure and there's plenty more that could be done to free up killerwasps. Tempted to venture down that path, but I reckon E85 will do much more for me and retain the stock appearance. Stao believes that the ATR comp covers flow slightly better than the Nissan covers...but they are roughly the same size so I was willing to give it a go.
Cheers man! Just wait for E-flex...visually it'll be no different, but the graph will be a different story!
Nah not sucking shut at this poundage. RP put a metal spring in there (similar to the GTR setup he said) which helps to keep it open...if it presents a problem down the track or when I tune on E-flex then I'll do the metal intake.
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
