Just a note. The excedy heavy duty can't hold 200kw.
Holding over 300kw (flywheel, where the rating is measured) without a problem for me. Don't spread misinformation.
Agree the Xtreme Motorsport clutches have also worked very well for me.
A car Ive done previously had the Xtreme button plate wear a little thin so I popped a regular exedy organic plate in it and its been running forevermore another 18 months of abuse later.
Here is a 34 i just finished tuning. Did a run before poncams and then tuned it after poncams.
Is running G3 older spec. This is with profec B spec 2 set to 0 but helping with holding top end (basically gate pressure)
Tao has sent a 14psi actuator that we will fit so can tune a low boost.
I tried more boost with this setup but kept nosing over and for the extra amount of boost there wasnt enough gain.
It saw 281kw with a bit more midrange on 21psi.
Tried advancing and retarding exhaust gear with no gain. So left at 0.
Also tried dropping the exhaust which automatically raised the boost to 20psi and made 281kw
Thats correct coupe.
The light blue run was when the dyno was playing up but it was reading the dyno correctly just not controlling the steady state.
I have tuned this car in the other (mainline) dyno and it made 232kw but has a different cat since then
Aparently I was lying before so here is the full details. I've got an rs4s running an excedy hd, stock turbo on 10/11psi it slipped a little, installed hypergear tuned to 220kw, slipped a bit more. Rebuilt engine and got clutch checked, nothing physically wrong with it or the flywheel, just doesn't hold.
thats does it I want cams now...
Oh wow. Am I reading the graph correctly in that the run with poncams made 53kw more top-end (ignoring the mid-range gain as well because I can't see that axis) with less boost? If that's the case then I may start thinking about poncams more seriously as well lol. What are the specs on those cams, are they Type-B's, ie. 260's???
I also agree it looks like a restriction somewhere though, what's going on with the shape of the curve Jez, was that caused by the exhaust?
Lol very true, between boost bleeding off, square wheels and my brake pedal causing earthquakes in my car. I'm having lots of fun chasing problems.
You were lying before, so how can I trust what you're saying now? :P
Seriously though, there are a lot of factors to clutches not holding up in specific applications. Your pressure plate may be worn which can be visually impossible to tell and the lack of clamping pressure, no matter how good your friction plate is, will mean slippage.
no u dont, what you (me also) need to do is get VCT running so we can get a fatter mid range! lol
Yeh but I'm already onto that and it hasn't costed me any money yet, that's no fun! :P
By the way, hoping to have results for my latest setup around the middle to end of this month. Just need to get my throttle cable issue sorted and then I'll book it in for a tune. VCT should now be working, so fingers crossed I've got it all right this time haha.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
