Problem is my housing is made the way it is with the gate attached..would be alot of effort to change it, making a new housing and all..I can do a billet wheel no worries though..
Try an "F1 racing" clutch, which also goes by the name "gripforce". I have one in my car and i know of several in cars pushing 300+rwkw and going for 2 years+. Not bad for a $250 clutch :thumbsup:
I managed to organise a clutch from a bloke in Sydney KB clutch engineering.
He came recommended by a few of the ACT peeps once of which is running one in their GTR which is still holding up with 5k launches.
The guy sent me the following quote via SMS so I dont know what it all is but this is how it came:
HD cover assy
HD clutch plate organic facing SBF
Release bearing
Freight to canberra
$410
Nothing wrong with organic for the street....though not sure about 5k launches.
I have a JB in the R33 and an NPC in the fat slug (so much better than the 2nd cushioned button that it replaced).
I had a extra x2 heavy duty organic and died pretty quickly with my old 33 and 250rwkw just slipped while driving in 3rd one day
If I did it again I would get a extra x3 heavy duty cushion button it's really street friendly and u won't need to upgrade any time soon and wont have to waste 350-400 for labor to fit another clutch when the organic dies
Have you got the part number?
http://www.ebay.com.au/itm/NISSAN-SKYLINE-R31-R32-R33-RB25-DET-ENGINE-/220939836848?pt=AU_Car_Parts_Accessories&hash=item33710a5db0
which do you prefer??
Those were the only 2 clutches I considered, otherwise I was going twin plate..
I ended up with a freshly rebuilt NPC 10' and flywheel for half price of a new one...
but can anyone tell me if flywheel bolts are 12mm cause if they're not I have a problem :unsure:..??
Both are great streetable clutches. I would be happy with either.
The JB required modification to fit, something JB denies was necessary but was required. It came with a Valeo pressure plate from memory.
The NPC/Exedy has been faultless.
I think I would have no issues doing above, infact I know the SS1PU is slightly larger then the GT-RS all around and was pretty consistent when on the dyno. I'll be back with few more wastegate side updates and can do some comparisons with what Trent's got in his PC.
Also found most tuners would retard timing as "insurance" for stock motor when it do hit 20psi. That explains the missing mid range, an update to the wastegate assembly is made, so all new units would have no issues holding boost using EBC with a 14psi actuator. Also the updated module is available for all ATR43 series at a cheap cost.
For that Billet TD06 there is no way it can be modified into a stockie bolton the possition of the turbine outlet is way off to stock 6 bolt nissan pattern. So it will have to be the way it is. I'm planing to let trent do some tests on his New Ceffero.
Trent should have a couple of GTRS tunes on RB's. I know Dave has one on there with nismo 555cc and EBC. Easy to compare...
Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel.
It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly.
Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2
Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange.
Just noticed in the Kando thread about cracked td06 turbine wheel.
http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/page__view__findpost__p__6306795
Compare to what you've offering for sale above, Since above is also made from the same origin, is yours same or better? any idea on whats causing the problem?
The turbine wheel bends backwards or break vertically during a course of impact. The horizontal crack is from Heat, some thing to do with the material content of the alloy its made of. Generally running E85 and external gate plus not so much boost would keep the EGT low, that avoids issues like above.
How ever I have seen similar problem from a T70 Chinese turbo years back that was used on a Ford 4L +T. The car initially made 370rwkws on pump 98 for a while before the driver noticed lack of performance through time. The turbine wheel had lots of horizontal cracks with chucks missing, the edge of the wheel blade appeared rough like a wire brush. Luckily the it was a old T04 copy so I managed to rebuild it with a geninue Garrett wheel and it was all good.
Most turbo builders would contract specialized foundries to forge their parts to the specifications they require. The single incident is not good enough to conclude Kando or all other Greedy copies are bad, certainly there are many more working examples plus mine is yet to be trailed.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
