Sucks about your clutch
Question for stao. Where do you turbine wheels come from?
As for reliability look what happened with the bw efr turbos
Manufacturing faults can and will happen
Just to give you an idea. I've had a 21U hi-flow for a while now. Over 45 track days down, pulled it off late last year and it looked perfect.
Birds did you go the 10"? For around the $650 mark?
I got a quote yesterday for one and the guy said its rated to around 400rwhp
Yer it was the 10. Bolts up to standard flywheel so that's a big plus. Wait til I tell my girlfriend I've got a 10" now!
Might be a stupid question, but where abouts are these clutches power ratings being measured at? If its only a 400hp clutch I hope it's at the wheels, but that seems like an odd place to measure it from for a clutch
Edited by Mitcho_7
They would be measured at the flywheel but you could give a rough estimation for how much wheel kw it can hold.
Well if the clutch is only going to hold 400hp at the flywheel wouldnt that be barely enough clamping force for the guys with the ss1pu's that have 250kw at the wheels?
??? In both Kasko and my posts, we refer to rear wheel power...
I'd rather they be measured at the wheels, that seems more practical to me given all our dyno readings are obtained there.
I didn't see the rear wheel part. If you guys manage to get your boost fixed up top and get say an extra 20kw you'll be closing in on 400rwhp won't you?
They tell me it's good for 300rwkw, so I'm going off that. Doubt I'll touch on 300rwkw...even with E-flex...my compressor housing is too small.
Im not saying its a bad cluth choice for youre power im merely asking Is 20-30rwkw enough wiggle room in terms or clamping force once the clutch wears abit? I'm interested to know is all.
I think you will be surprised Birds, and the torque hike will only make it worse.
Guess we'll find out, but it's a risk I'm willing to take. Worst case scenario I flog it off to someone who has less power and opt for the not-so-pleasant-sounding alternatives: fork out $$$$ for a JB, put up with the violence of an HHHDB, or do both of these things and get a twin plate.
I'm not drifting/racing the thing, I just want a clutch with enough clamping pressure to hold things together under load during the daily drive with the occasional spurt...I think it'll do the job fine. Keep in mind these power ratings are only a guide...there's no point splitting hairs over 300rwkw, not like the thing will magically pop just after 299.9rwkw and I don't think NPC would be selling their clutches based on power ratings if they weren't a tad conservative.
NPC Twin plate ;)
Talking to a mate the other night who has one, he reakons its the best clutch he's ever used. I'm half kicking myself I didnt just get one from the start, but oh well, I'll see how long the 10" single plate lasts. So far its been great but :)
NPC Twin plate ;)
How long has it already been in there?
When I spoke to NPC he said his mate was running one in a 300kw car so it should be fine
Same with the quote from KB clutches
He asked for my peak power/torque and what rpm it makes these by.
He then spent a few hours and got back to me with the organic
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
