Guys,
How about starting another thread "For Clutches" as this is starting to hijack the Hypergear Turbo thread.....
Dont get me wrong (its all interesting as I will need one soon so i am whatching what is said) but its getting a little off topic for poor Stao & his fantastic turbo's....
Just a heads up ok dont want to put any nose's out of joint so to speak....
Dazza
If Stao has an issue with it I'm sure he'd say so. He indexes all the pages in this thread so it's not like it's difficult to find the sections relevant to your interests. I think this is a pretty important part of the turbo selection process as people should know what works with what. I like that the threads, both Kando and HG take a focus on helping people with their whole setups instead of just focusing in the turbos. We're like macro communities :)
Its good to have documentation from all range of supporting mods working with the turbo. I will index them in the main page.
I've been taken some time off working on my electric turbo again. lol here are some latest updates:
The new charger runs of 44V 120AMP of power from a 2x 6S power source with RPM controller.
I've installed it on to a Daihatsu Sirion with a 3cyc 0.97L engine. This car makes from 0 to 100KMs in 21secs factory. lol
After appling the charger in 3rd gear full throttle it actually made the Speedo rising a tinny bit faster. There is a just noticeably acceleration gain with the charger is activated and not. I'm installing it on the R33 for dyno runs next weekend. hopefully making better result then the previous one.
Plus I'm working on a VNT .82 rear housing for the G3s hopefully getting SS1PU's response with 330rwkws top end.
Can this new VNT housing be made for external gate? I just purchased a wastegate and highmount so as discussed a month or so ago my turbo will be comming back to you soon.
Will try and get it off this weekend
Trying to decide if i should send you guys my stock rb25 turbo or buy one off you or buy a GTX30/76, chasing 400-450hp, what would you sell me? i would like too stick too Australian products.
Edited by 51NNA
The limit for a Bolton G3 on a stock exhaust manifold would be 400rwhp with proper mods on pump 98, unless if you are going for E85 then you can get that 450rwhp+ (abe's R33 358rwkws).
Or you can high mount It run external gate, which would be the best solution for the goal, and reduces the cost in building the turbo to just $1000. We also have a externally gated turbo called the SS3. That would reach you goal with possibly the best response.
Pump 98 results and details from that turbo is in page 120
It was a billet wheeled turbo based in a SS2 externally gated housing. It was very responsive how ever only worked well externally gated, internal gated version was about 30kws short. Its a very different turbo to the G3, how ever you can run that rear housing with it and the results won't be far off.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
