We actually build a brand new turbo core with bigger wheels, then machine your stock housings to suit it. We only use steel turbine wheels. So are you actually getting back a brand new turbo inside your factory housings.
yup i understand that but is it possible to just put a standard size steel wheel in there, ie no machining etc?
Yummy.... $1300 basically... what kind of response and power am i looking at with this rb25 highflow ?
I would say around 280rwkws with high pressure actuator. full boost by 4200RPM. be just like this one here:
(Dynosheet below is running a normal 1KG actuator)
http://www.digi-hardware.com/images/dynosh.../atr43360hp.jpg
and No we can not get standard size wheels in steel.
obviously with supporting mods.
what psi was he running?
With the high pressure actuator will i be seeing better results ? than that of the 1kg one ?
small edit : Even tho i hand you a turbo with shaft play and all that jazz it gets fixed anyway correct? so i can go buy any turbo in hindsight and still get a brand new one back ..?
Edited by v8tzr
With the high pressure actautor you will be seen a lot more steady sort of line with out the drop. and will be making more top end.
Once high flowed you basically get a brand new turbo back in your stock housings so it doesn't matter if your current turbo is blown or with heaps of shaft play.
The old and blown CHRA in your stock turbo goes into the bin unless you want it back.
As someone from South Australia where the inspectors will basically look for any external changes from the factory turbo to defect you - is it possible that the external of a Hypergear highflowed RB25 (R34) turbo will look identical to the factory turbo? Are there any lines that require changing? Is it possible to retain factory lines, or is it a requirement to go to something else?
I'm guessing changing the wastegate actuator would be an obvious visible difference too - so despite performance benefits, it would be better to use an RB20 (10psi) one or keep the factory R34 (5psi) one to avoid Transport SA issues?
Well visually the high flowed turbo appears to be same as the stock turbo. You can use your stock actuator. Or we can modify your stock actuators actuation bracket to suit a high pressure actuator.
Few new projects and updates for 2010:
First of all few of you already know We've started developing VARA project in Mid dec 09. Which allows us to change your turbine A/R to what ever we need it to be. Means we can now high flow your stock R33 (yes your stock 2IU turbine housing not OP6) turbos to produce 270rwkws if need to. So we are no longer boxed by the flow limit with some smaller turbine housings.
2ndly as we all aware that smaller turbine housings gives us better response but not good up top. with our Variable Air Ratio (VARA A: actuator controlled) turbine housings. We can start off with a .42 A/R till 7psi and have it increased to 0.82 on 20psi refer to boost increase. Means you can have 300rwkws with stock alike response. This response is also adjustable with a bleed valve. This method has been used on few turbocharged Porches, we will be intergrating this into Nissans.
3rdly We will be building .60 compressor housings with stock size inlets and out lets. So people are no longer required to get any "Kits" as it bolton to your stock every thing.
I will be posting photos once I get back on the 15th of Jan.
Happy new year every one.
Hi Stao,
Can the VARA turbo housings be put onto one of your already highflowed R33 G2 turbos to reach the 270kw mark or do you have to redo the whole turbo.
How much would this be?
Hi Stao,
We can modify your R33 turbine housing for lot better flow which class under the PU highflow options. So basically yes we have to modify every thing on it.
The VARA is still under development at this stage. will be ready for public soon.
Excellent result Lowrb. Please post dynosheet when possible. Thanks
And will the response still be the same but with more top end?
Nah...you'll have more lag as per a bigger turbine wheel to create more power. More power usually equals more lag when it comes to turbo upgrades :rofl2:
Until Stao gets this VARA thing happening for us :domokun:
that's what I meant Birds, same response with the VARA????
Well that's the idea behind it anyway. I doubt it'll be exactly the same as stock but it should be much better than a straightforward high flow without sacrificing top end :D
hey stao just wondering say if i give u a HKS2535 turbo can u like put bigger wheels on it and like make the housings flow more if so how much? and what would the response and hp be like?
Cheers
Chi
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
