  On 25/04/2012 at 12:13 PM, hypergear said:
how ever I'm recently seening some 260rwkws results based on 15psi from Toshi's remaps using stock injectors, afm and ecu.
Sounds like a high number for stock injectors and afm.
I wouldnt trust a number like that
Magic. Trust in magic!
Never the less, injectors, AFM, ecu. Should see 240-250rwkw on 14-16PSI on a 21U.
I call high dyno reading @ 260rwkw on standard fuel system without a high pressure regulator or something...it'd be absolute knife edge. Back in the day it was always ~230rwkw max for the standard gear, what's changed?
nothing
just one guy claiming he can do more
  On 25/04/2012 at 8:45 AM, Pattey21 said:
Hello, ive got a r33 s2 and wondering what is your best hi-flow turbo for response, only looking to make 220-250rwkw, stock internals with associated mods. Its a daily and would be looking to run between 10-14psi max.
cheers
Agree with Tao, standard high flow would be best for that power, though I think you should consider going the extra step and getting a hybrid SS1PU...it won't be any laggier than the high flow and will give you some extra head room down the track should you want to run more boost. My R33 is a daily and the SS1PU is great in that role.
Toshi mentioned some thing to spool turbo without fuel to increase power. I don't deny or fully understand his concept but the results are extremely tempting. I guys it would be good of toshi can enter some input.
I dont fully understand anything Toshi says, anything he says appears in text boxes and my eyes get an error saying 'language not installed'.
FWIW though, I trully believe theres more to tuning then adding timing and pulling fuel. I know his theory is that the stock injectors are sensitive to pressure, getting choppy above 15psi, so i would say increasing rail pressure is also a shitty idea if hes right. The combo of stock FPR and stock injectors run at 15psi seem to be Toshi's 'sweet spot' for tuning.
Forgive me for thinking aloud here, but injector spray pattern would have a lot to do with the burn and in turn would change how effective the burn is. By 'rule of thumb' 370cc is 370hp on an RB25 = 277kw. With some deduction the ability to hit 260kw on a 'happier' dyno is definitely there.
Or we could just keep screwing boost into things coz thats all that makes power. T25 on 40psi runs 10s (till destruction).
  On 26/04/2012 at 6:00 AM, ARTZ said:
That's 370 at the flywheel though...which is around 230-240 atw ..
I don't see how it is when i know of cars doing 400rwkw on 555cc injectors.
400kw=540hp. Allow 15% for "happy dyno fun times" and there's your drive train loss.
HEAVILY MODIFIED 300ZX
ENGINE BUILT BY UAS
  • Custom GT28RS turbo's.
  • Extrude honed exhaust housings.
  • Plenum and 55mm throttle bodies.
  • Custom UAS Cams
  • Adjustable cam gears.
  • Porting.
  • ACL pistons
  • Custom top fuel rail.
  • Nismo 555cc.
  • UAS Twin pass radiator.
  • UAS FMIC.
  • Microtech Computer.
    This is a car i looked at buying for some time but the price was just too high. It was at UAS a fair bit.
Its not happy dyno.
I tuned S15 on same dyno (MX5 mania dyno) and I made 198kw.
http://www.nissansilvia.com/forums/index.php?showtopic=497151&hl=toshi&st=0
He went to unigrup dyno day and he made 207kw on unigrup dyno.
You can ask him over PM.
ENGINE BUILT BY UAS
  • Custom UAS Cams
  • Porting.
  • ACL pistons
  • Nismo 555cc.
  • UAS FMIC.
ED"*"*
Ok I stand corrected, now show me one RB.... :glare:
  On 26/04/2012 at 8:16 AM, Toshi said:
Its not happy dyno.
Toshi it will he good if you can explain the method (doesn't have to he in great detail) about how you can make 260rwkws on a stocky high flow and factory injectors and why most other tuners are straggling to pass 230rwkws.
Just to clear things up i will run one of toshi's highflow r33s on the dyno for free. If it is possible it would be awesome.
Tao we will be trying the new nozzles(bolts) on elusivity's ss2 next thursday. Are there any tricks to this ?
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
