ARTZ Posted April 27, 2012 Share Posted April 27, 2012 I would like to see an rb20 make 600hp with 600cc injectors Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6332969 Share on other sites More sharing options...
hypergear Posted April 29, 2012 Author Share Posted April 29, 2012 Just to clear things up i will run one of toshi's highflow r33s on the dyno for free. If it is possible it would be awesome. Tao we will be trying the new nozzles(bolts) on elusivity's ss2 next thursday. Are there any tricks to this ? Those wastegate studs you are inserting will reduce the area of the wastegate making boost creep uptop same as if you've got an wastegate that is too small. Except the extend of creep is fully controllable. Insert a stud at once. Method is debatably but I've used it quite often at trents and it appears to be working well. Also an update. This is the very first billet SS1PU core that we high flowed into a M35 Stega's OEM turbo for a Scotty's customers. The car made 300rwkws on the auto with E85 at about 20psi of boost. I'll still need to take acount in modifying the OEM wastegate assebly on those for better boost control using this core. Will upload dynosheet later. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335156 Share on other sites More sharing options...
Birds Posted April 29, 2012 Share Posted April 29, 2012 Damn...someone beat me to an ethanol fueled SS1PU Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335329 Share on other sites More sharing options...
Mitcho_7 Posted April 29, 2012 Share Posted April 29, 2012 (edited) Damn...someone beat me to an ethanol fueled SS1PU At least you now know how good it'll be! Or you can spice it up and go water/meth injection instead... Edited April 29, 2012 by Mitcho_7 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335458 Share on other sites More sharing options...
Cowboy1600 Posted April 29, 2012 Share Posted April 29, 2012 I would like to see an rb20 make 600hp with 600cc injectors The injectors are capable of enough flow for ~600hp. Doesn't mean the engine is. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335634 Share on other sites More sharing options...
Birds Posted April 29, 2012 Share Posted April 29, 2012 At least you now know how good it'll be! Or you can spice it up and go water/meth injection instead... True...I wondered if the potential for 300rwlw is there, off my restrictive setup. I can see me needing a metal intake at a minimum. Ethanol all the way baby... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335645 Share on other sites More sharing options...
GTScotT Posted April 29, 2012 Share Posted April 29, 2012 Birds you should get some custom pipes done to look like the stock ones but have a few less bends (stainless and painted black) Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335653 Share on other sites More sharing options...
scotty nm35 Posted April 29, 2012 Share Posted April 29, 2012 Damn...someone beat me to an ethanol fueled SS1PU Beat you to it Birds. True...I wondered if the potential for 300rwlw is there, off my restrictive setup. I can see me needing a metal intake at a minimum. Ethanol all the way baby... Drop in, I can make an 80mm intake for you tomorrow if you like. Yours should be an interesting ride on ethanol, they have pretty good response don't they mate. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335921 Share on other sites More sharing options...
ARTZ Posted April 29, 2012 Share Posted April 29, 2012 Is that the blue wagon that was in pieces a week ago Scott ? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335934 Share on other sites More sharing options...
scotty nm35 Posted April 29, 2012 Share Posted April 29, 2012 Yup, drive in, drive out 300kw in two weeks. Not bad... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6335950 Share on other sites More sharing options...
Birds Posted April 29, 2012 Share Posted April 29, 2012 Beat you to it Birds. Drop in, I can make an 80mm intake for you tomorrow if you like. Yours should be an interesting ride on ethanol, they have pretty good response don't they mate. I'll definitely be visiting you for one, but I want it mated to the standard airbox, which I still need to acquire first. Plus I have to install my clutch Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336035 Share on other sites More sharing options...
hypergear Posted April 29, 2012 Author Share Posted April 29, 2012 Here's the copy from Scotty's customer. This turbo was made as a bolton high flow using stock housings. The actual SS1PU run a .60 comp and .84 rear which is bigger in A/R compare to OEM M35 housings so the end result could be better. How ever VQ25 is a totally different class of engine plus the Auto trans they are not the same to our Manual RB25dets. I'm also in the process of adapting that TD06SL2 billet 20G, how ever I'm a repeat offender to EPA and has been fined a large sum of money in the past for not obeying EPA modification guides. Knowing the next fine would be extremely high, this is a major concern. There is ambiguous statement listed in EPA's guide such as: External gates are not allowed, and all exhausted gas must filter through a catalytically converter. So by word "external" stands for bleeding into environment without filter through the cat, then plumbed back would be considered as "internal" gate? Or if I add a 2inches muffler plus a small cat into the screamer pipe would also make that Internal and street legal? comments from any one's been dealt with those matters with EPA earlier would be appreciated. Thanks. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336040 Share on other sites More sharing options...
DVS JEZ Posted April 29, 2012 Share Posted April 29, 2012 Tao sorry to hear. The issue with trying to run a cat in the creamer pipe is they need to be a certain temperature to operate which means unless u are flogging around on a race track i doubt they will be hot enough Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336076 Share on other sites More sharing options...
adam999111 Posted April 29, 2012 Share Posted April 29, 2012 I'm pretty sure its no external wastegate at all. Regardless if plum back because it changes emmisions from stock. An emmisions test and/ or engineers cert. Is needed Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336088 Share on other sites More sharing options...
Mitcho_7 Posted April 29, 2012 Share Posted April 29, 2012 I'll definitely be visiting you for one, but I want it mated to the standard airbox, which I still need to acquire first. Scotty made me a metal intake and it fitted perfectly with the stock airbox on my 33, but I'm running a pod with a box around it now. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336147 Share on other sites More sharing options...
GTScotT Posted April 29, 2012 Share Posted April 29, 2012 Its pretty disgusting to find out you have been getting fined by the EPA Stao. As a manufacturer you are able to produce any item without risk of being pinged by the EPA, you just need to pre-warn your customers that the external gate is not road legal and should be used for road use only. What happens though is cry baby customers get done by the EPA and cry that they bought the turbo like that from you. That's weak and low. Man up to your choices people. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336191 Share on other sites More sharing options...
hypergear Posted April 30, 2012 Author Share Posted April 30, 2012 I was epaed long time ago on my sil180 the last time was due to a high mount manifold so I could change turbo easy on it. That came with a pretty heavy fin. The skyline with the stock manifold and internal gated turbo has not been epaed, it has been defected how wver it was for none secured power steering bottle. In this case might have to drive the car to Trent with no waste gate. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336245 Share on other sites More sharing options...
Birds Posted April 30, 2012 Share Posted April 30, 2012 I'm also in the process of adapting that TD06SL2 billet 20G, how ever I'm a repeat offender to EPA and has been fined a large sum of money in the past for not obeying EPA modification guides. Knowing the next fine would be extremely high, this is a major concern. There is ambiguous statement listed in EPA's guide such as: External gates are not allowed, and all exhausted gas must filter through a catalytically converter. So by word "external" stands for bleeding into environment without filter through the cat, then plumbed back would be considered as "internal" gate? Or if I add a 2inches muffler plus a small cat into the screamer pipe would also make that Internal and street legal? comments from any one's been dealt with those matters with EPA earlier would be appreciated. Thanks. lol welcome to my world mate! Now you know why I insist on running a restrictive, yet EPA friendly setup External gate will refer to any wastegate external to the turbo, not how the gases are bled out. I don't think you'd get away with that loophole, but even if you did, the turbo being aftermarket will surely earn you a defect. Its pretty disgusting to find out you have been getting fined by the EPA Stao. As a manufacturer you are able to produce any item without risk of being pinged by the EPA, you just need to pre-warn your customers that the external gate is not road legal and should be used for road use only. What happens though is cry baby customers get done by the EPA and cry that they bought the turbo like that from you. That's weak and low. Man up to your choices people. I don't think he's getting fines for manufacturing the items, I haven't heard of that happening before. He's getting fines for his own vehicle. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336253 Share on other sites More sharing options...
GeorgesR34 Posted April 30, 2012 Share Posted April 30, 2012 apparently if you do get caught with external gate on a RB that is 6 penalty points (1 point is roughly $1000 fin). So regardless how good running external gate is and blah blah I'm just going to stick with my high flow. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336268 Share on other sites More sharing options...
GTScotT Posted April 30, 2012 Share Posted April 30, 2012 I don't think he's getting fines for manufacturing the items, I haven't heard of that happening before. He's getting fines for his own vehicle. Ah ok, if its his own vehicle thats fine. I have known mechanics to get slammed as bad as losing their blueslip license after people complain their mech did the work and didnt inform them of the legalities. I just hope that sort of thing doesnt happen here, we all know the consequences of running that sort of car on the road. Its the individuals choice/risk. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/246/#findComment-6336309 Share on other sites More sharing options...
