This is a SS1 none PU version. It maxes around 250rwkws with same response as a factory turbo, it never worked on this stegea. So I'm happy to have it upgraded to other series at no additional cost.
30rwkw isn't far short, especially considering not many of your customers turbos equal what your test car makes. If you could figure out why it isn't holding boost then I think it would come a lot closer.
No the average of 250rwkws was taken from 3x different cars. they all run up to about 17.5PSI top end, they were 253, 247 and 245. The final afr is all about 12. The best run of 260rwkws was on 23psi.
I couldn't figure out why its not holding boost on his car. I guess its better to exchange for a SS1PU or G2 a G3 which results are well proven by many people.
Or I can exchange with some thing that comes straight out of my car like the G2 I've done for your self and we ended up with same power.
No the average of 250rwkws was taken from 3x different cars. they all run up to about 17.5PSI top end, they were 253, 247 and 245. But the afr is all about 12. The best run of 260rwkws was on 23psi.
I see, but still not far off.
Thing is, what if the turbo isn't the issue? What happens if whatever replacement turbo you send him then doesn't make power? Doesn't look good.
The turbo it self is bit on the small side as it was only made to do a maximum of 250rwkws with factory response, and it was more responsive then a stock turbo. During that time the FNT housings and billet wheels wasn't developed.
Since he's got forged engine, so its no differ to mine, it doesn't hurt to go bigger and bigger is more consistent with power and boost control.
The strangest thing I noticed is we couldn't get it up to 20psi, the higher reading was at 16psi down to 14psi, he said there was a massive heat soak and the timing was just going ridiculous. On e85 he thinks it could make 250.
For the time being I can't afford another tune, my rego is due, so I can't really change the turbo right now. As much as I would love to.
here is my dyno graph from yesterday. The car is a 96 r33 gtst and has the op6 standard hi flow, nismo 555cc injectors, nismo fuel pump, blitz turnflow cooler (heat wrapped pipes), full 3" exhaust and a metal intake. Real happy with the result, thanks Jez!
Edited by Mitcho_7
Looks like a good clean tune, should run really smooth. Can definitely see the difference between the standard highflow and the SS1PU.
Yeh the ss turbo's build boost faster but can't seem to hold it as well uptop. I had one of staos wastegate mods on initially but the boost wouldn't go below 20+ psi...
Edited by Mitcho_7
Glad ur happy Mitch. If i go to shop later i will overlay ur graph with Kasko's and post it up.
Would love to see this as the ss is $700 more expensive.
Question Jez even if mine could hold the 20 psi through the whole rev range it would still be limited by the detonation above 250kw?
Yes it should make more power. Fuel octane is always an issue when trying to push bigger numbers from a smallish turbo, Say if u had a G3 u can run more power with more boost before u hit the knock limit.
I think due to the turbo design being for as best response as possible the top end has to suffer as it chokes up in the rear housing.
That's cool I'm really happy with the response so I don't want to lower that just for a gain in power.
Maybe once I get bored of the power bit I doubt that would happen any time soon.
Even with the clutch still not replaced I managed to break traction all the way to 3rd gear last night.
Let's just say I won
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
