When I took off I heard this voice say "your shifting to early wind the gears out"
Wonder who put that in my head was huh Jez
I admit it im a bad influence. But i am a good teacher, atleast u know when to change gears now u pussy :P
When it stops making power? hahaha at 300rwkw, I stop changing gears by the RPM, kinda have to play it by ear....literally. Far too focussed on the road.
He was changing at 5500 or some pussy rpm
I admit it im a bad influence...
Not really, I remember when u were tuning my car u kept telling me to take it easy n slow down as i was revving the sh** outa all gears so u cud tune the upper rpm points too.. Ur kinda good influence I reckon..
Docile every-day driving I usually change around 4000rpm, but the few select sections in this every day driving I give it what for as I would on a weekend - ~7000rpm shifts, not letting revs drop below 3500. hahaha though this is rare :(
Docile every-day driving I usually change around 2000rpm, but the few select sections in this every day driving I give it what for as I would on a weekend - ~2500rpm shifts, :(
because Diesel Van
Yeh the ss turbo's build boost faster but can't seem to hold it as well uptop. I had one of staos wastegate mods on initially but the boost wouldn't go below 20+ psi...
I'll wait for Jez to post the overlay graphs, but IMO the SS1PU comes on faster and has a better top end. Maybe you're thinking of the SS1?
I wasnt really expecting to get a result similar to an ss1pu, they are like $700 more and are a superior turbo. You would expect them to outperform a standard hi flow easily.
Im happy with the result, but if I ever get over this setup (highly doubt I will for a while) theres always the option to sell up and go bigger with something like gtx3076 later on if I wanna chase a larger number.
Edited by Mitcho_7
Haha ur a hoon
Had to chime in Jez, pot calling the kettle black anyone.............. :) :)
You've driven my car so I have first hand experience lol ;)
Ive never seen my semis so "ungrippy" heheheheee
because Diesel Van
hahaha yes :P though I'd say about 500rpm more than what you suggested. 2nd - 5th are all pretty long gears, and I've found there's really no need to wind it past 3000rpm in any gear.
Lmao Dave i have no idea what u mean :P
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
