  On 08/05/2012 at 1:16 AM, DVS JEZ said:
New rule from now on. If a customer has a
Cold they are not allowed to bring the car to me until they are better.
Damn u Elusivity. My cold sucks balls
So it wasnt breathing in the fuel fumes from my injectors etc for a solid few hours that made youre throat sore... I think you are contagious prior to actually feeling cold symptoms, so I hope i dont get sick now considering you were in my car for ages spreading your cold everywhere haha!!
Edited by Mitcho_7
Yeah everything seems tight from what we can tell. Taking them to Jax today to get another persons idea on it.
Seems like a weird noise like a rattle as if the whole thing is loose.
Will know soon enough
I also have a rule for this, where people aren't allowed within metres of me until they are better. Not much annoys me more than catching someone else's cold.
And if you didnt catch it from someone else, where would you catch it from Birds? lol
Or are you just always annoyed when you get sick?
*cough* Avengers *cough* Dr Banner is ALWAYS ANGRY
Sorry Jez! I seriously didn't think I was contagious, you're also gonna have to blame my GP for telling me otherwise... I'll make sure I and you are 100% before I bring the car back. :yes:
  On 09/05/2012 at 10:51 AM, DVS JEZ said:
While i think of it i overlayed kasko's ss1 pu and mitcho7's op6 highflow
Very similar results for the $700 price difference
Or do you think it's justified for that midrange difference in 10kw
  On 09/05/2012 at 12:21 PM, ARTZ said:
think I'd rather have my 700$...
Only one way to settle this though Kasko...fixed your clutch yet...
I would probably to now looking at it.
He could probably pick that midrange up with the extra 2psi
Arrived today
I declare a race haha
Or Mitch and I can go to the dyno day in June here in Canberra $50
We've compared that too, The difference on road could definitely be felt, which is why I choice the current configuration for the SS1PU. Or it could be going to a .63 rear housing with the G2's turbine wheel. The dyno doesn't show the power delivery. Plus I believe there are lot more left in that SS1PU with the arm extender holding 20psi.
Some one must've coughed into their shipping box when sending in their turbo. Felts like I'm in the early stages of the cold.
On the positive side, I've made a miniature version of the G3, you can call it G2.5. Its smaller, with better response, and made to produce a top of 300rwkws. Testing that on Friday.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
