Good luck with everything Hanaldo!
What is a decent low mount exhaust manifold to upgrade to from the stock r33 one? Ideally one that would allow the use of the same dump/front pipe?
Finally started car for first time after installing the ATR43 G2 in the car and I'm a little worried. First turned car on for short period (1/2mins just making sure all intake setup was alright and no vacuum leaks) and saw steam start coming off the turbo so turned car off straight away.
I hadn't put coolant in the car yet so I hit myself in the head then refilled it all waited a little while and started car again. Was letting it idle to bleed the coolant and again lots of steam started coming off the turbo pretty quickly. Am I being paranoid or is it likely my coolant feed has gotten blocked off? I am still using the steel lines and obviously had to 'adjust' them so that they would fit up to the new turbo.
It's more likely to be smoke. You most likely had a bit of oil on your hands or you dripped a bit from the oil line, which is now on the rear housing or the dump pipe. It will just smoke a bit until it burns off, nothing to be concerned about.
Mine bellowed smoke for a good couple of minutes burning all the shit that I put on touching it the whole time.
Give it a few minutes and it will go away.
If it doesn't then check all the water lines going to it.
99% it's going to be the dirty turbo
Yeap. Every time I do a turbo on my own or another car I get lots and lots of smoke as it burns off my grubby paw prints.
Just make sure you are checking for liquid leaks. No leaks, no worries, let it keep running.
Awesome thanks guys I know i def got oil and such on the turbo my hands were covered in crap haha. The turbo shouldn't get hot enough to damage it on idle even if it is getting restricted water going through to it do you think?? I mean the oil is still flowing through it and some turbos are oil cooled only.
I looked for leaks and didn't seem to be any which I was happy about
Just make sure the oil line supplied with turbo is used and actuator is tightly shut with preload. Then that will he fine. Water is optional, they also works fine with no water.
Check your heater drain hose isn't fouling against the turbo too, this will give you a burning rubber/mechanical smell when the turbo heats up. I tied my hose back with a cable tie and it's been sweet since.
could have also cracked a water line when manipulating it, pissing a small stream of coolant onto the rear housing/dump pipe
easiest way to tell: what does it smell like?
S1 R33
3 inch dump,high flow cat, 3 inch exhaust
Apexi metal intake pipe with pod --- problem?
China fmic --- problem?
044 fuel pump
660cc high flow injectors
Superspark coils with copper plugs @.8
Nistune ecu
Eboost street
SS1pu
277.0hp @17psi
There isn't any boost leaks, we checked while there. I also double clamped all the pipes to make doubly sure.
I did check at the time whether i pulled all the rags out as well.
It's got me stumped, any ideas??
Drop the exhaust, that seems way too laggy.
Brand spanking new Apexi n1 pro installed on saturday.
I know whats wrong. Because he's from Perth. :D
Could be, could be ;)
Although last week the egt light came on for 2 minutes, then went away. But i checked out the cat when i put the exhaust on and it looked ok (3 months old)
This turbo generally makes a responsive 260rwkws with 18psi of boost, confirmed by couple of members.
Pre-dyno tuning you should have:
Proper aftermarket ECU that is designed for the model of engine
It appears to me like a R32 ECU + Nistune with no VCT activation.
Mechanically sounded engine
Make sure compression are good, base timing is correct and matches with ECU data.
Spilt fire coil packs with correct “copper” spark plugs
Good quality fuel injectors and a good fuel pump with a new fuel filter.
Good and effective 600x300x75mm intercooler, that excludes most of return flows.
Have a feel on the cold end with your hand after each dyno pull. Good cooler remains cold.
At least 3inch “metal” induction pipe with a free flow pod filter. This excludes:
Re-enforced or modified based on stock rubber intake pipe
Random ebay cast metal pipe made for factory turbo.
Custom pipe that goes into a sealed factory airbox.
If above is what you have make sure you change it refer to working examples from this thread.
At least 3 inch free flow exhaust
Excluding certain restrictive cats
Excluding restrictive mufflers
Good way to test it is by dropping off the exhaust pre-cat. substantial gain means restrictive exhaust system.
The last thing is the Tune. There are bad tune related examples from Perth, and there is very little that I can help with, apart from sending you a Nistune map based on the same turbo for reference. Give a try at "All star garage".
If there is a sincere believe of a fault on the turbocharger, then I'm happy to have it fully tested on a good setup in return of testing result and tune map, any defects found will be repaired.
No way am i disrespecting the turbo, i'm just after peoples opinions as to what could be the problem.
I will try a new fmic setup and a 3 inch all the way intake though, the apexi one is 4 inch - 2.5 inch.I'm starting to lean towards the cat at the moment tho.
As far as the Nistune, it's out of a zx and vct is fine, timing was also checked at the tuners.
I'll keep scratching my head, i guess i was hoping for someone to say "that's what's wrong you f***ing idiot"
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
