price was about $1000-1100 the one on his car atm it a IG version with no port for EXTERNAL WASTEGATE
but he is talking to brae atm about getting some prices and designs for a external wastegate version
my one cost $1150, I'm inquiring for a quantity of 10 at once to get the price down. Even with discount it is still too expansive for most people to accept.
Yeah I'm tossing up on whether to get a new manifold or not. I know it will help but its a bit of money for a decent one. The 6boost ones were my pick so far but open to other ideas :)
lol
Did you end up getting your Dyno fixed? I got a big chunk of Kia sportage here that I'm sending down for dyno tuning.
Have a loan controller coming over from NZ as we speak (so maybe 3 more days till we are back on the go).
New controller is still 3 weeks away.
Stao, is SS2 meant to have a spacer plate? Just saw your updated DIY fitting instructions and there is no mention of it but it's in the photo. Is it only for G3 or SS2 aswell? No mention on page 1 in the ads for the turbo
no need for spacer, The spacers on the test car was made for turbos with larger comp housings.
There are 2 more Billet SS2 prototypes that should out perform the current SS2 on certain areas, just waiting for Trent's dyno to be running and have them tested, of course you are welcome to send the old version back for the latest update assume the prototypes did out perform the current version.
I sat it on the manifold to see how it looks and noticed the compressor housing rests against the manifold heat shield so I was just a bit worried the outlet hose may get too hot. I can always slip a small spacer in next week or so before putting the engine back in
I'll have a better look tomorrow and get back to you. Cheers Stao
Most bigger turbo upgrades require cutting out the heat shield to allow for that slight bit of room
Yeah that's the other option. Prob wouldnt need to cut it up much either. Or heat wrap if it's too close
Here is the link to Brae's manifolds:
http://www.braeautofab.com/
And you can get the RB bolton manifold for $1100, it requires some of fabrications to fit, not a big deal. but ask him to have a external gate port made just in case external gate might be installed.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
