Have you done the SS1pu on e85 yet?
Would be really interested
Really not liking the idea of always having to run 20psi to get 250rwkw when these other turbos that people are strapping on are making simple 240 etc on lower boost such as 16-18psi
Pm me or post up here if you could
Cheers mate
Aside from where it's sold, can you think of any reason why not to as a tuner?
It makes their job too easy, no challenge, as it's not on the verge of knock all the time. :)
Seriously, the only reason not to run it is the extra fuel it requires, larger fuel system, less k's to the tank. The positives outweigh the woeful economy tenfold. Clean engine, more torque/power, lower temps, cheaper, environmentally friendly, not having to line the pockets of thieving oil companies...
Shhhhhh. :D
Haha copycutter availablity is the only issue. Oh and supposedly it melts fuel rails and ruptures fuel lines etc etc according to people that dont like ethanol for some stoopid reasons
Shhhhhh. :D
Hurry up Penrith E85 pumps!
I might be wrong but how is running e85 cheaper?
its $1.18 vs $1.50 at the moment. and say it burns 30% more $1.18 is equivalent to $1.53 in petrol cost. so not cheaper now but the power gains is a benefit for virtually the same cost. but when 98 goes up which it will, you will save.
O_o. Plus a new fuel system. So I guess it's much like gas. Some people will do it thinking oh this is a great idea and the rest will just continue on with their lives. Although I was told that the only way my hypergear will be reliable is with e85 as it heat soaks really bad. In that perspective I can see why stao is listing the e85 figures. Let's get some more dyno sheets in here already. Any more testing done yet?
E85 won't be +30% if you do mainly highway of say 80km/hr+ kms... my GT-T got to +10-15% on 98 fuel economy with E85 and that was back when E85 was 97cents a litre... was much winning :D
and to the person thinking of going z32 ecu nistune - i think change your ecu plans, FC or Link plugin. Nistune is great, and i highly recommend it... but for 33 owners, there are better options.
You know there's a United with E85 at the top Old Bathurst Rd in East Blaxland now? That's only 6 or 7km out of Penrith
Surely the 'Riff will get one soon.
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
