The boost drops off a fair bit up top.
303kw on about 22psi droping back to 19/18psi is a decent result, but it doesnt seem that much different to the g2.5 in terms of response.
The g2.5 made close to that power running 98 on only 20psi didnt it? and pretty close to 200kw at 4000rpm as well
Edited by Mitcho_7
Yeah it's looking like the turbo I'll be after. Want to hit 300rwkw or near enough and hopefully shoot above with e85 if it's ever readily available where I live.
Was gonna use stock manifold but after looking what Stao has said and the Dyno graphs I think I will look at getting a 6boost or brea manifold, depending what is available to me
The temptation to go external gate is there, but I think I'll stand by internal gate
same turbo just pump 98 internally gated. Only shows bit more responsive on paper, but on road its very different to the G2.5. Further response gain will cost top end power unless going external gate.
How ever small differences do adds making a pretty big difference looking back to the old G3. So just have to keep on working at it.
Results from the newer SS2 prototype on Pump 98 internally gated in bolt form. It made final of 302rwkws and did actually manage 200rwkws by 4000RPMs. Pretty sweet to drive on road. At this stage that every HP its getting is based on a trade off of some response. Probably only a tinny bit more room to play with. I will trail one more wheel on it in about a week time.
Wow I'm excited. Glad I sent it back for updates.
What is the difference between this and the other wheel you will be testing next?
Different profiled wheel blades, also complete with a bigger turbine housing.
I've made one more billet wheel with minor alterations to the hub that I like to get some result off.
Just over-layed new Ss2 against old ex gate 307 result and original 315 int gate result on paper.
New one is impressive. New vs 307 are identical from 4500 to redline. 307 makes more around 3700 but dips at 4100 then they meet up.
Original 315 makes less from 33-5500 of up to 60hp then only makes a bit more to redline compared.
Excellent result
Stao,
Any hope in a twin scroll internally gated turbo making somewhere over 300rwkWs on 98 & full noise around 3500 to 3700 rpm?
Here's an example of what the EVO boys use:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-VEVO-039&Category_Code=NEW
The idea of running twin external gates etc.. too much money & space used up.
Just put hi-lighter over it. Forgive how rough it is etc.
Yellow is original 315 result
Blue is 307 ex gate
Green is new one with .82 rear
Maybe Stao can get proper comparison sheet when he try's next wheel
Edited by t_revz
Stao,
http://www.atpturbo....tegory_Code=NEW
If that turbo was on decent boost before 5500rpm I would be supprised
Edited by SimonR32
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
