  On 30/06/2012 at 11:06 AM, jet_r31 said:
Stao, in your eyes, what would work best if you had 2 options with the ss2, a internal gate ss2 on a brea manifold..or a external
gate ss2 with ext gate put on stock manifold?
cheers
darren
At this power level if using stock mani port matching etc I would imagine to make quite a difference. Pretty sure Abe with G3 port matched and was 350-360kw
  On 29/06/2012 at 1:43 PM, hypergear said:
Further updates. This is the 2nd SS2 prototype been trailed. More responsive and made more power to previous version. Internally gated.
Max of 312rwkws on BP 98 and 210rwkws by 4000RPMs
Stao is this 100% 98 fuel or could there have still been e85 in the tank for the comparison? The difference between all ss2 models at 3700 is huge with this version way in front!!
Stao do u supply an external gate n low mount turbo package(no brea manifold), if so, what gate is it and how much for package and also for gate separately? Good quality gate?
This has been on my mind
I didnt even give that a thought, buy It's probably highly likely there is eflex still in the tank, because I doubt the tank was drained between the different runs.
It would account for why there is such a large improvement over previous ss2's. I'm sure part of the improvement is also down to stao re engineering housings/wheels as well though!
The e85 has been drained by the fuel pump. And filled up with 20l of 98. Difference was about 10 degrees of timing. The 98 runs appears to be slightly more responsive.
So potentially there could have been 2 or 3 litres in tank before adding 98. If so next time you fill up it might start pinging?
I drained mine off the pump other day and I could still see fuel. I only just got new Bosch pump and weather has been too crap to see how much is left in there. But at least a litre minimum maybe 2
Yeah easily. When i convert to e85 normally have to run 20litres of e85 to help flush the left over 98 then refuel e85 and finish tune
Well my car's on E85 full time now. It keeps every thing clean including engine oil, and E85 servo is just 500 meters off road from where I am. My current pump is wabro with a rubber fuel pickup hanging off the bottom, there could be a 1L of E85 diluted into 20L of 98.
E85 generally makes a average 40kws more then 98 then lets say it maxes at 300rwkws on pure 98 on my setup, generally means maximum of 280rwkw when fitted on stock manifold internally gated.
Either way I'm pretty happy with the final result as it had the most area under the curve for the power level it archived, with brilliant road drivability.
  On 01/07/2012 at 10:40 AM, Mitcho_7 said:
If only it was that simple!
Mitch tax time!!
Then you and I are road tripping to Jez's for a tune on this magic juice.
Stao what would you expect the SS1PU to be pulling on e85 stock manifold.
280-290? Or will it max out
Chuck it on your car and show me haha
  On 01/07/2012 at 11:54 AM, Manuel Kasko said:
Mitch tax time!!
Have you thought about how youre going to get home, because it's 400 odd kms and I don't think you will make it on one tank of e85. Is there a servo on the highway that sells it?
Might have to carry a few jerry cans with you?
Edited by Mitcho_7
Well, there are no differences in fuel between the two runs, They all been drained out through the fuel pump, and the pump had a rubber pickup that sit on the bottom of the tank. So the fuel are identical. The 98 was carried in 20L drums and removed on the end of the run using same method. The tank is then filled up with E85 again.
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
