both those clutches are cushions. the way you tell is if there is a full disk or if there are paddles.
full disk are cushion (theres a wave plate between the two outer surfaces), paddle clutches are the non cushion type.
my favourite type of clutch are the multi paddle ones, sprung centre and 6 or more paddles. they are rarer, the exedys are usually 3, 4 or 5 paddles as a maximum. the more surface area you have the friendlier the clutch is to use. I think thats a better way of making the thing manageable than a pissy wave plate.
that being said ive got a pissy cushion button in my car too :P
  On 04/07/2012 at 3:06 AM, Rolls said:
cushion apparently, but it was TERRIBLE to drive, shuddered and f**ked my gearbox, in the end it still had massive bite and shudder but would slip on hard changes to 2nd.
I am renowned for having no mechanical sympathy haha.
Those symptoms point to the clutch being highly glazed.
you should order an organic HHHD next time. high clamp load but a forgiving material.
Yep that is what I put it down to as well, too much trying to slip it in traffic driving to work no doubt caused half of that wear opposed to actual abuse.
I ended up getting a Jim Berry organic after that, was much more appropriate, nicer to drive and held the power/abuse just as well. Have a similar thing in my r32 now, organic exedy HD I think with uprated pressure plate, holds 260 no problems.
yeah an organic isnt as bad as people think they are provided the pressure plate has the right clamp load.
i tend to recommend them over buttons in most applications.
  On 04/07/2012 at 2:07 AM, Rolls said:
I raise you my button clutch, I did this just daily driving the thing ; ) Totally destroyed it, you can see the heat discolouration and warping of the rivets, with only 150rwkw as well lol.
I did nearly exactly the same thing to the same clutch with just shy of 200rwkw. Didn't get thrashed to often and one day just started slipping. No such issues with the NPC :)
lol Dan, yours makes mine look like a brand new clutch. Speaking of which, reco gearbox and new clutch are in. It was dragging at first, so I swapped in a longer slave pushrod and adjusted the pedal. Now the take up point is a little too high, so I have to adjust the pedal again -_-
Only been on a short test drive, but she feels great so far - no more crunchy gears and the organic clutch is very friendly. Can't wait for my 1000km run-in period to finish, then I can see how this NPC holds up to the SS1PU...AND GET AN E-FLEX TUNE!
you should order an organic NPC next time. high clamp load but a forgiving material.
fypbrah
Yeah the poor thing took a beating!
So I found the rattling noise in my clutch goes away when I slightly touch my foot on the pedal this is before the pressure point.
Should have it back out in the next week and then we will know what's going on.
Can't wait to see your 85 tune and what power it makes! As soon as tax comes im hitting it up and also going to get stao to swap me a 14psi actuator
  On 04/07/2012 at 9:09 AM, GTScotT said:
Lmao kasko the clutch killer.
never driving my car, good effort tho :P
Oi shhh! Don't tell people or I will never get a drive. Nah but honestly it was my first manuel car I have ever driven and also couldn't handle the SS1PUWERRR
Edit: I blame the SS
For anyone interested this is my setup that will be installed by the weekend, ss2 0.82 type b rear, ext gate 44m tial with screamer
and a comparison of the rear housing and wheel from factory
  On 04/07/2012 at 9:52 AM, Manuel Kasko said:
You belong in the wasteland with a mouth like that! Damn whore you are
LOL just geeing, will be fun either way
  On 04/07/2012 at 10:17 AM, adam999111 said:
According to stao I have the most recent one. So not the lightweight one but the one after. Lol. Too many to keep track of.
Pretty sure the last 2 weight the same it's only design that is slightly different. I'm also getting most recent version
cool, what fuel will you be using?
You got both internal n external gates.. What the.. Welding the internal gate shut?
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
