My engine head gasket went last night on the dyno due to a bad wiring in the fuel pump lol. I was about to test it out. So hopefully in about a weekish.
The new pump requires an additional earth. By the way it is a walbro F9000262 400L/Min pump. It works once plugged into the stock loom but doesn't create much pressure. Once additional earth is connected it worked fine. How ever didn't help the head gasket.
Don't know why people use anything but the good old 040. Never heard someone complain about one!
Cant forget the Nismo pump, it plugs right in, is good quality and pumps and decent amount of fuel :yes:
Having used three of them in the last week I have nothing bad to say about them other than that they are driving me mad by failing right out of the box due to clogging!
(I realise this is not a pump issue :P)
Birds, even the 040 needs a good power supply, in fact I would be upgrading the power for any aftermarket pump as they require up to 4 times more current. Stao found out the hard way that the stock wiring can't supply 17 amps. Sorry to hear mate.
Because we are cheap bastards Birds ;) Do wish I had gone with the 044 back when I did my fuel pump, didn't think it would be necessary at the time though. Nor did I realize how good a noisy fuel pump sounds!? :P
Interesting that it failed on the dyno though, was the fuel pressure not being monitored or is it just one of those things?? Makes me want to check my fuel pump, though I have rewired mine and has been sweet so far.
I had 040 in my Sil180, when the metal filter blocks it makes a loud whining noise. I had to pull it out and clean it once every couple of weeks, on the end I teared the mash filter out of the bottom and that worked fine and stopped the whine. lol
The walbro more or less bolton to stock bracket, and it had an walbro in there for 4 years without much issues.
That's what I mean though...040 is so cheap I don't know why people don't just go for that. Still using stock wiring at 260rwkw, no issues with fuel supply...will see if it lasts when I switch to ethanol.
Must have had a dirty tank Stao, or had the pump sitting right at the bottom. Nearly 2 years on and mine never whines!
Unrelated: gearbox running in period approaching it's end; have been giving my car more frequent bursts of full throttle. I've said it many times and I'll say it again, SS1PU ftw. Lastnight was cold as ice and she was throwing my mate back in his seat hahahaha.
If u put a flow gauge on aftermarket pumps with engine running u will see how much upgrading the wiring helps. Yes u can just do the earth mod but i always prefer running a relay with a strong battery supply.
Why not rewire yours? It's cheap and easy to do.
No need to, yet :/
Wouldn't wait until there is a need, by then it will probably be too late and a whole lot more expensive. You're probably wearing out your pump a lot faster by running it at low voltage, Bosch do say to run it at a minimum of 13.5v.
Hi, going to book a tune this week, just wanted peoples opinion on an ECU, I currently have Power fc with Z32 afm. But i was thinking to go down the path of Adaptronic and go with a MAP sensor?
What are your preferences, to help me make a decision, as i dont know what to pick. Its only between the two so please don't recommend another ECU
Both will give the same outcome. But u could sell the power fc, afm and boost controller if u have one and use the adaptronic with boost solenoid so it controls boost
I'm not going to be using a electric boost solenoid, so that feature will be void, but for tunerbility and power potential, would AFM (power fc) or MAP (Adaptronic) be better? If they are similar and outcome will be the same as you say, is it worth the hassle of selling the setup i have now and going Adaptronic? On a side note, Adaptronic uses wasted spark, will this affect life of the coils or produce a lot more heat in the engine?
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
