have you/ do you intend to run and atmo bov? If so, go the MAP sensor route.
On a side note, can the adaptronic have duel maps/flex fuel setups?
Edited by Mitcho_7
Yeh. The adaptronic supports flex fuel by interpolation of fuel consumption. That's what the manual said anyway
But not sure about 2 separate maps.
Yep you can setup it to run flex fuel and switch maps.
Could something be restricting my setup do you think guys? Seems odd that's now 2 guys making more power then me on a lot less boost.
I understand different dyno etc etc
But just wondering if anyone has any opinions?
Tis decent compression, maybe look at the cooler like was suggested
Did Jez drop the exhaust at all to see if it was causing a restriction or were you pressed for time?
Edited by Mitcho_7
Finally got mine SS1PU tuned. It made 255rwkws on 16psi. Dame responsive to drive. will upload sheets later when I get a scanner.
nice result mate, congrats
Z32 AFM
3 inch exhaust (decat)
555 injectors
SS1PU
Nistune
3 inch intake
Splitfire coils
Hybrid front mount
Umm have I missed anything
Mine has:
3.5 inch exhaust (decat all the way though)
550c injectors
SS1PU
Adaptronic plugin (Used to have a wolf 3D)
3 inch intake
Splitfire coils
Unknow cooler came with the car.
The best run was 261rwkws when car's cold, and average is 255rwkws after couple of runs. sheet is attached.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
