  On 28/07/2012 at 2:44 PM, ARTZ said:
Does look clean..dont think I have seen a yellow one before...
Should look clean, everything went through the acid bath or sandblaster at work. Respraying yours yellow now?
Prob Just a pod. Haven't bought hoses yet to fit inlet. Dummy fitting crossover pipe now to check recirc hose fitment. I'll take pics as I go scotty. Also dump pipe fouls on a/c drain so will double heat wrap dump pipe at that section and maybe remove outer black tube.
Made any heat shields for these Scott? Could pick up off top 2 dump pipe bolts easily. Might have a crack at something once it's going
Since my car's off the road, I've managed getting Brae to have my existing manifold modified for an 50mm external wast gate.
We are also in the process of making an simpler exhaust manifold that is in factory style with larger inner diameter made to support an 50mm external gate (or can be left internally gated) at a very affordable price. It should be a bolt on item to factory setup, and holding the turbocharger in factory position. It is designed for for the ATR43 bolt on series or any standard bolt on high flows, I will have that trailed when it becomes first available.
Don't like lobster alloy pipes? Sorry if it isn't pretty enough for you. :P
The inside is dead smooth, it will make the power, with no bov reversion. Can you post a pic of your design?
  On 31/07/2012 at 3:44 AM, scotty nm35 said:
Yeh but it doesn't say Greddy and you can't see yourself in the polished reflection.
I make practical intakes that work, not fap toys. lol.
Exactly my thoughts mate, your product is proven to work, is good value for money and I cant wait to get one installed on my ride :)
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
