I'm waiting for a cometic multi layer metal gasket from usa. I'm not in a great hurry as Brae needs about one more week to have the new manifold made. I will announce price of them once they are successfully trailed.
Yea, for on my car it was around 3 degrees of timing increase for mid-top range. the power band keeps on rising instead of dropping and the torque curve also becomes lot more spreaded. I will do few runs with the new manifold compare to my current one (expansive one) and see if there are any differences. But either way I'm sure a 50mm gate will make some differences.
I make practical intakes that work, not fap toys. lol.
hey I'm just in the process of making my own metal intake - what's the reason for not just using mandrel bends? is there any, or you just loooove welding lol?
80mm alloy pipe won't fit well in the stock configuration, and I can't find mandrels in that size. As it is the same size as the AFM it just seems smart to keep it similar for flow, and 80mm silicone is readily available now.
3 inch pipe may just fit to the stock airbox with alloy donut bends but there is no way (currently) I can make them the same every time, manufacture them remotely and guarantee they will fit. It's quite hard to make a product and ship it across the country without making sure it is consistent, I can only do that with the lobster cuts.
If you needed shiny mandrels you could take your car to any of the fabricators on here, they would be happy to make a stainless or alloy version for you as would I, or make it yourself by all means. Will it perform better? No, it's only for looks, and if you don't follow the few basic rules in construction you will have all manner of issues with it. (unless you go map sensor and ditch the AFM)
PM me with your ideas if you like and I will run through the basics. Stay away from silicone bends as when hot and soft it will suck in and put you in the same position you were with the stock intake.
Update on the M35 VQ25 turbocharger high flow profile.
This is the small profile using the SS1 core. Also run FNT turbine setup. should have stock alike response with much stronger punch. Running with after market ecu I would expect it making some where around the 230rwkws mark.
The whole chra is about 15mm shorter then OEM chra, All lines fits fine (oil line needs little bending), the drain pipe flange needs to be slightly skimmed.
They charge $90 per seat at most places, why on earth would you pay that to essentially get two holes drilled?
Because the RTA wanted them added to the engineers certificate, they needed to be done CORRECTLY. That means correct location as per ADR, which falls inside the speakers. He needs to fabricate a 'bridge' style mount that goes over the speakers themselves but under the mesh, then a bolt through the mesh into this bridge.
May I say, the ADR's are a load of crap if that's the case. (I already new that anyway.)
What's the cop going to say when he sees the speaker holding a child seat down. lol.
that intake pipe is an abortion....
If only your mother knew of the word! :P
Most of us here are more concerned with kilowasps and efficiency than checking out our gelled hair in the reflection of a pipe...but each to theirs I guess!
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
